52 ford f8 cab same as f1??
Discussion in 'The Hokey Ass Message Board' started by willys_truck, Jan 5, 2012.
  1. willys_truck
    willys_truck
    Hello, I am wandering if a 52 ford f8 cab is the same as a f1 cab, if there are differences what are they? Thanks
  2. blt2go
    blt2go
    i've been told that my 49 f-6 is the same so i would assume yours is too. as i understand it the wheel well opening and running boards are the only difference between them. could be mistaken. wouldn't be the first time. good luck.
  3. poncho62
    poncho62
    Pretty sure thats right....and, those big ass mirrors
  4. Dale Fairfax
    Dale Fairfax
    Ford use ONE cab for everything from F-1 to F-8. The hoods and grills were also the same. The fenders differed-I believe F-2 Thru F-6 shared fenders; F-7,8 had their own.
  5. willys_truck
    willys_truck
    Thanks, that is what i needed to know.
  6. Yes, this info is correct. :)
  7. blt2go
    blt2go
    this is why i hang out here so damn much!!!!! bunch of people that know gobs of stuff just putting it out there for all to see!! viva la hamb!!!!!!
  8. NAT WILLIAMS
    NAT WILLIAMS
    used F-8 cab for my 48 pickup, same cab just had holes for the air brakes and lights on top. You know the grill and fenders will not work.
  9. bobj49f2
    bobj49f2
    The cabs are all the same, I have a cab from a F-7 on my F-2. The only differences are the transmission cover and dash post. There are usually a few extra holes in the floors for PTO handles and transmission parking brake.
    F-1 have their own fenders, F-2 through F-6 have the same front fenders. Grills are the same for F-1 through F-6. F-7 and F-8 have larger and wider front fenders and the grills are wider on the bigger trucks.
    Here's a page I have set up on my web site:
    http://fatfenderedtrucks.com/partsinterchange.html
