I got stock shoebox IFS. Everything is cleaned up, lower control arms bolted back up to the frame and im bolting the spindle support to the upper control arm. I got new seals in place and pumped it full of grease. But there is an ass load of slop that wasnt there before. I don't have the lower arm bolted to it yet with the spring in place, which would put pressure on it, but it still seems to me like it should still be tighter. It's almost like the tolerance in the threads is excessivly loose. Im positive it wasn't like that before I took it apart. Is there something I missed or did I do something wrong? All I did was clean the parts.
