OK, guys. here's the deal. The guy who owned this car before me, decided to undercoat the entire bottom with por15. Upon doing so, he spilled some of the por15 on the paint in a few places (single stage enamel) is there any way to get this stuff off, without damaging the finish underneath? Thanks for your thoughts
patient use of run razors and nib files might do the trick, followed with some rubbing compound https://www.google.com/search?q=pai..._sm=122&espv=210&q=paint+run+shavers&tbm=shop
I had the same problem with one off my cars. I was able to pick a corner of the por15 and peel it off on a heavy drip or run, the lighter stuff like a fingerprint or smear I buffed and got it cleaned off. I like the idea of using the nib file or similar mentioned in another post that sounds like it may work well Posted using the Full Custom H.A.M.B. App!
ANY way of removing this is risky. I personally would avoid a razor blade, and stick to chemicals, patience, and buffing... Posted using the Full Custom H.A.M.B. App!
The above, and be sure to cover the paint around the ''Poor 15'' with masking tape, and only file and sand the Poor areas. After all traces have been removed, remove the tape, and rub out.
Thanks for the info guys. I didn't even know those run razor tools existed. I thought about trying a razor, but know I am not steady enough to do it by hand. I'll look into that. I might also add, that the guy who painted this thing didn't get near enough paint on it, so that is a concern as well, when it comes to color sanding and buffing it out
