'51 Ford Turn Signal Wiring Diagrams Here
Discussion in 'The Hokey Ass Message Board' started by mcload, Jul 2, 2007.
  1. mcload
    mcload
    I don't know if this is of interest or use to anyone, but I have scanned the assembly/wiring diagrams that came with a '51 Ford turn signal assembly. I tried to put them on the technical archive forum, but I apparently don't have those privileges yet. If someone wants to move them for me, that's okay. Anyway, the drawings are here:
    <O:p</O:phttp://www.mcload.com/1951 Ford Turn Signal View A.jpg<O:p</O:p
    http://www.mcload.com/1951 Ford Turn Signal View B.jpg<O:p</O:p
    http://www.mcload.com/1951 Ford Turn Signal View C.jpg<O:p</O:p
    Hope someone can use them!
    By the way, when the picture opens, right click to either "save picture as" or "print". The first diagram is a "portrait" print, the other two are "landscape" prints.
  2. SlowandLow63
    SlowandLow63
    from Central NJ
    Holy shit you rock. I love it when other people make things easier for me. Just about to start wiring mine up and everything else is a cinch, cept for that. Now, I'm covered.
  3. Jack Luther
    Jack Luther
    Thanks. I'm planning on using a '51 column in my '29 roadster project, and I want the signals to work. Any ideas about how to make the horn work? The original horn wire ran down through the center of the steering shaft, but that won't work for me. I'd appreciate any help in that regard from anyone here on the hamb-- please pm me with your thoughts. Thanks. Jack Luther.
  4. Da Tinman
    Da Tinman
    Wow Dude ya got ESP or sumthin. Just got turn a signal switch and was gonna look for instructions tonight,, Guess I'll just have to look for porn instead!!
    Thanks a bunch!
  5. mcload
    mcload
    Jack: I had to go to a solid steering shaft with u-joints, so I can't use the center hole wire either. If I'm not mistaken, that wire is simply a ground, so that when the horn button is pushed, it connects the circuit making the horns blow. However, I don't yet know if Ford used a horn relay or not.
    So I was planning to just include a ground wire (from horn button) in the side bundle of wires that runs down from the turn signal switch (and is covered by a small piece of channel). This way it won't show, and can be connected to whatever wire is needed to make the horns work. Just make sure this wire makes good contact with the horn button somehow. I don't think the horn wiring is addressed in these schematics, but I could be wrong.
  6. SlowandLow63
    SlowandLow63
    from Central NJ
    That should work great. Ford did have a horn relay here. Mine is still sitting on the firewall. The wire is providing a ground and any common 12V relay will work with it. Thanks again.
  7. lonewolf
    lonewolf
    does anyone have a copy of the links in the original post that no longer work, It would make my life alot easier thanks
  8. Me too. can't get the link to work. I'm trying to wire up the turn signals and brake lights on my car to register it.
    thanks,
    Jimmy
  9. mcload
    mcload
    Jimmy and Lonewolf: Send me your e-mail address and I'll send you the wiring diagrams. Sorry the links no longer work.
    Patrick
  10. koolmotor
    koolmotor
    Patrick, could you please send me turn signal diagram on 51 ford ? I try the links nothing came up. Thanks Pat email: koolmotorshop@yahoo.com
  11. Thanks I got to figure out the wiring for my Willys and that will help a ton.
  12. grf-x
    grf-x
    After all. Just picked up a 51 ford or custom. Could i get a copy of those files. I'd like to wire up some turn signals on the ole gal.
    grfx@wowway.com
    Thanks
  13. yblock292
    yblock292
    Man perfect timing, wiring my 51 right now and was just getting ready to do the original turn signal wiring..........Thanks a million!
  14. yblock292
    yblock292
    Me too.......... yblock292jlm@yahoo.com
    thanks again
  15. 4Door51
    4Door51
    If u still have the diagrams can i please get a copy..tryin to wire my car now..thanks again...email is raymond6851@gmail.com... thanks again for your help
  16. Claude Smithey
    Claude Smithey
