Technical 51 flathead timing cover bearing
Discussion in 'Traditional Hot Rods' started by zurawski, Jan 18, 2015.
  1. zurawski
    zurawski
    from wisconsin
    I am wondering what goes on the back of the timing cover the shop manual said something about a "camshaft thrust bearing surface" does something go there if so does anyone have any pictures and/or know where i can buy what I need????
  2. metaldave
    metaldave
    from michigan
  3. metaldave
    metaldave
    from michigan
    I think the bearing surface is just a bump in the casting that keeps the cam from moving forward. I may be wrong as its been a while. I dont think it is a seperate piece
  4. flatjack
    flatjack
    It is a part of the cover. Nothing needs to be added.
  5. zurawski
    zurawski
    from wisconsin
    My cover dose not have any wear marks on it I would have thought it would if there was no other part there?
  6. Kiwi 4d
    Kiwi 4d
    Is this an aluminium or steel cover? The 8ba cam thrusts forward and does use the cover as a thrust face sometimes they can be a little worn on the alloy covers but a rule most are ok to be reused. There is no bushing or shim in there.
  7. zurawski
    zurawski
    from wisconsin
    I have the aluminum cover
