1950 Ford Two Door Custom Sedan Owned since November 2007 this is a solid mild custom you can enjoy now. Extensive work and many new parts went into its construction. This is a unique Reno, Nevada area shoebox as the toe boards, floors and trunk are rust free. The rockers were cut out and replaced as were the front fender lowers. There is no other metal work to do. Bare metal respray with metal sealer and DuPont DP 50LP epoxy primer. Nosed, decked, door handles removed, gas door welded in, frenched tail lights, 96 hood louvers, new door hinges, fender skirts, wide white Diamondback radials and pin striping on gray primer set this off as a 50’s era cruiser. The engine is a custom build 302 Ford with an aluminum radiator, backed by a C4 automatic with less than 1,000 road miles. An 8” Ford differential, 3”+ drop on all 4 corners with front disc brakes and Volvo steering box get the job done. New carpets and insulation go with the tuck and roll door cards. All new wiring harness too. No cup holders or fuzzy dice. The asking price doesn't cover the materials to build this shoebox Ford. Current registration and clear Nevada title in my name in hand. Picture file, spare parts, receipts and tech materials go with the car.
