Looking to see if there is any info out there for mounting a late model 5 speed box behind a Flat head six dodge..Looking to do some up grades to my 49 dodge truck and this idea was one I`m interested in trying.anybody ever try it??
Hi Fitzee, With all the torque of the old six, I wonder if 4 gears might serve better. The fifth would add an OD effect, might be fine. I'm thinking back to some of the old monsters like the 409 Chev, in a light car, 3 speeds was the best choice.
You might have to be real good friends with a machinist but it should be something that can be done. the Dodge overdrive that I have has a longer input shaft than the GM or Ford transmissions I have so you might check to see how the 5 speed compares to the Dodge trans if you have both there.
http://stoveboltengineco.com/index....:category=412400&mode=product&product=1396066 http://www.wilcap.com/webdoc8.html Tom has been very helpful to me in the past. Highly recommended. There are also guides if you do a google search. Good luck.
see what I`m after is have the truck so it will keep with highway speeds.In and around the city it is ok but to and from home it is a 20 min run on the highway.. reasoning for the 5 speed.. Going to look into this more.. great info..
fitzee, My 38 Plymouth flathead had a t5 behind it with a 3:78 rear end gear. It was awesome on the highway. I also had split exhault manifolds and a 2 carb intake which rounded out the package nicely. It is worth it. Langdons is the place to get it (1st link above). Paul
I put a camaro t-5 behind a flat head dodge in my roadster. The truck bellhousing has a large enough flat area to redrill the gm bolt pattern. However, the bearing retainer register OD on the transmission is smaller that the ID of the register hole in the bellhousing, it's about 0.05" too small. Also the dodge truck throwout bearing ID is way larger than the stock gm one. I made a bushing for the bearing retainer register and for the throwout bearing. I also had to make a new pilot bearing. I used a stock 10" gm clutch and the pressure plate from the dodge. Dodge truck had a 10" and 11" clutch. If you want to use a t-5 from an s-10, then you will have to space the trans as the s-10 input shafts are longer than the camaro and standard muncie/saginaw 4 speeds.
