I put together this list the other day for personal reference, and just wanted to share the info for those who might need it! I work at NAPA, so these are all Echlin part numbers, but the counterman at whatever your store of choice is should be able to cross them. These are all regular old 12V, Type B relays, with resistor across the coil (pins 85 & 86), except where noted. I denoted the ones with no rating listed as "light duty" to be safe, and would assume this to be under a 30A rating. I would personally use these purely for "changeover" duty and not for your air compressor or the like... AR143 --light duty, with plastic tab AR274 --light duty, removable metal tab AR170 --Light duty, no tab AR174 --Light duty, shrouded, provision for metal tab (but no tab included) AR272 --Medium duty, 30A, no tab AR276 --Medium duty, 30A, metal tab, shrouded terminals AR426 -- 40A, no tab AR201 --Heavy duty, 50A, no tab AR204 --Heavy duty, 50A, *diode across coil*, plastic tab AR419 -- Kit with color-coded pigtail, butt connectors, and what looks like an AR276 relay EC23 -- color-coded relay pigtail EC38 -- pigtail with little mounting tab
Be aware that ANY plug-in Bosch type relay is ONLY rated for 24 continuous amps as that's the maximum rating for the wire connector. They are useful for circuits (generally motor circuits) where inrush current exceeds the relay rating as they'll give longer contact life/fewer failures, but still shouldn't be used on circuits beyond 24 continuous amps.
Good addition!!!! True, terminal/connector ratings definitely need to be taken into consideration, and are often completely overlooked. I would note, though, that even the "light duty" relays listed are used as continuous duty headlight or A/C clutch/blower motor relays in their original application, and should be fine for similar application in a hot rod. Thanks uncle buck!! I wasn't aware of that P/N and will add it to my list!
Would a AR170 cross over to a hella 87152? I’m trying to find a horn relay for a painless wiring fuse block?
