4x4 Chassis
Discussion in 'The Hokey Ass Message Board' started by Stephen67, Oct 15, 2009.
  1. bubba57
    bubba57
    from k
    I'd go with the 77. How bad was the 97 rolled? It might have damage to the frame and running gear that you don't notice now. I'm doing a 49 International on a 66 Chevy 1/2 ton, 2wd frame.
  2. Stephen67
    Stephen67
    Yeah I'm debating from the '77 and '97 right now. I like the simplicty of the older trucks, no computer problems, fix them yourself...
    the '97 was rolled at about 30mph, he drove it back home about a mile and a half. Haven't seen it in person yet... haven't seen the '77 either though, ha.
  3. bubba57
    bubba57
    from k
    If the frame is good on the 97, that would make a good donor also. All you need is the frame , no computer to mess with.
  4. Stephen67
    Stephen67
    True, I guess if I did swap out the 460 to a 351w I wouldn't need the computer stuff anyways...
    The '77 should have a wheel base around 117"
    The '97 should be around 152"
    The '56 Long bed was set at 118". That 1" might not matter, I had planned on making the bed a bit custom. The '97 would for sure have to be shorter.
  5. bubba57
    bubba57
    from k
    Why not extend the bed instead of shortning the chassis. Might be alittle easier. Just a thought
  6. Stephen67
    Stephen67
    Depends on how long... could look REALLY funny, lol
  7. Stephen67
    Stephen67
    Ok, so it turns out I grossly underestimated the weight of the facotry flat bed and the axles, resulting in grossly, grossly, over estimating the weight of the f-600's chassis. It weighs about 200#s more than the f100, not the 2000#, lol. And it probably weighs about the same or close to anything I'd end up swapping with it...
    So I'll be swapping parts rather than the chassis.
    I am currently eye'n a 1997 F250HD for a donor. The axles on that thing should very well match the rest of the truck. Right now the '56 Turns, moves and stops like a ship, so I will also be swapping the steering and brakes.
    It has a 460 in it with an auto trans that needs some work. I believe the transfercase is divorced but I'm not positive yet, hopefully it is. The 460 is going to be killer for a daily driver, so I am thinking a 351w would be the way to go. Smaller, lighter, and lots of power potiential if I ever decied I need more.
    So hopefully this will all work out, lol.
  8. murfman
    murfman
    What he said^^^ That truck would be sweet painted a mustard yellow with a white grill, and bumpers, along with some skinny TSL Radial swampers on it and some white steel wheels.
  9. 34 Plymouth Hemi
    34 Plymouth Hemi
    You might want to consider swapping out the 460 for a diesel!!
  10. metalshapes
    metalshapes
    Tech Editor
    Trad Hot Rods & Customs...
