Hot Rods '49 Hudson Project needs a two-piece Driveshaft Help!
Discussion in 'The Hokey Ass Message Board' started by airbrushguy, Feb 28, 2020.
  1. airbrushguy
    airbrushguy
    from NJ
    I have put a Cadillac 500ci engine and Turbo 400 trans in my '49 Hudson Super. I think, with tunnel adjustments I could possibly use a 0ne-piece driveshaft (60" long) however I doubt I will be able to lower the car much if I need to after I install the Chevy rear and put it on the ground.
    Can anyone suggest a two piece driveshaft and carrier bearing I could use, probably no wider than 3" ?
    Thanks in advance.
  2. MAD MIKE
    MAD MIKE
    from 94577
    If you are looking for a common two piece shaft that may be close enough in length.
    Try looking at 2WD long bed S-10 P/Us.
    They used a two piece shaft and carrier bearing.
    Wheel base on those trucks was 123"
  3. studebakerjoe
    studebakerjoe
    Long wheelbase Toyotas are another place you can find 2 piece driveshafts.
  4. I used to convert my Stude hotrods from two piece to one piece shafts when I started upping the power and really getting rough.
    I was concerned about the carnage if I ever broke something.
    The carrier was right about inline with the rear of the front bench. Thats where the driveshaft would rub the floor if I lowered the car.
    I saw-cut away a portion of the transmission tunnel about 6-8 or so inches wide under the seat to keep the new heavy duty driveshaft from rubbing.
    Once I did a few tests to confirm the driveshaft now had room, I screwed down a portion of driveshaft tunnel from some donor chevy or something.
    I just brushed on a bit of undercoating, then screwed it down. Sealed nicely.
    When I laid the carpet back down over the new hump, you couldn't tell I changed anything.
    I have probably not helped you much. I just wanted to say it worked with my Studes.
    I dono if Hudson used sharper angles or tighter spaces to make it more difficult. But it works great on Studies
    I remember seeing a lot of junkyard 60s Chevy trucks with some pretty stout looking carrier bearing and shafts.
    Maybe a transplant from a full sized Chevy pickup back when they used 2 piece?
    WHY BE ORDINARY ?
  5. goldmountain
    goldmountain
    Not sure if it helps but I remember 70's era Cadillacs had constant velocity u-joints on the driveshaft.
  6. airbrushguy
    airbrushguy
    from NJ
    I am using the Cadillac's long-tailshaft TH400. I am coming to the decision to go two-piece after trying my best to cut frame crossmembers and floor tunnel metal. I have the trans tunnel cut and raised enough, all the way back to the rearend yoke, but I'm afraid the 2-3" clearance is not enough for road holes and bumps.
    So I decided that if I mount the two piece, I will only have movement after the carrier bearing and I won't have to worry about much clearance thus the tunnel is lower and intrudes less into the seat placement.
    If someone has installed a two-piece in their car, could you tell me what was the requirement for mounting it....like
    , is the first driveshaft mounted level with the frame and when I cut the driveshaft, is there an ideal length to put the carrier bearing at or a proportion of front to rear shaft sizes?
    Thank for your help!
  7. lilbdfrd
    lilbdfrd
    I used a 1 ton Chevy van 2 piece drive shaft for my 1960 Lincoln 5.0 swap.
  8. oldskool.
    oldskool.
    from florida
    CK series 67-72 Chevy/GMC 4 wheel drives use the driveshaft you are looking for/
  9. KustomKreeps
    KustomKreeps
    Are you running airbags or lowered suspension? if so then i doubt a single piece drive shaft will work.
    I had mine custom made up in my 49 Hudson thats running a 9 inch rear, 700R4 trans.
    I can dig out the details of what parts i used if you want. But since im on airbags and the rear part may differ from what you need as I have more travel to deal with.
    I looked at heaps of different drive shafts before going custom. Holden had a few. Landdrovers also. Toyota hiace. but by the time I got it all customized, balanced and made up it was deemed all new parts rated for the HP and torque would be the best option.
    I also run multiple drive shaft loops.
    further details on my build thread in sig that i have been to lazy to update lately.
  10. airbrushguy
    airbrushguy
    from NJ
    I am not using airbags and would like to remain at stock or a tiny bit lower height. If I cut into and raise the original crossmember under the back seat and right before the rear, I create almost three inches above the nose of the differential. However, if the stance needs to be lowered in the slightest way, I might hit the floor on a tough bump or pothole!
