49 chevy sbc/th350 conversion question
Discussion in 'The Hokey Ass Message Board' started by shilde6, Jun 23, 2012.
  1. I'm doing a sbc/ th350 conversion on my 49 fleetline.
    Not sure if I need a short or long tail shaft trans or if it doesn't matter.
    I'm just worried about driveshaft length and angle. I'm using a s10 rear.
  2. squirrel
    It doesn't matter. The short tail transmissions are usually easier to find, in case you need to replace it. But if you might swap in a 700R4 later, the long tail 350 is the same length as the 700, iirc.
  3. deto
    deto
    X2 doesn't matter
  4. Register now to get rid of these ads!
  5. 51pontiac
    51pontiac
    from Alberta
    In my 51 Canadian Pontiac ( same as Chevy) I used a long tailshaft tranny and the mounting pad was farther back than the crossmember - I used a Chassis Eng crossmember kit and engine mounts.
    I had to do a bit of "adjustment and modification" to make it work. Basically I made a bracket to move the mount back a bit (it was too long ago to remember any dimensions).
