Technical 49-52 Pontiac fastback rad issue
Discussion in 'Traditional Customs' started by Don task, Mar 30, 2020.
Tags:
  1. Don task
    Don task
    Hey dudes I was wondering if you can help me out. I am putting a 350 in my poncho and was wondering if I can use the stock rad. I was curious if it will hold the pressure of a 15 psi cap. If not can I get it recored to solve the problem? I really don't want to spend 600 bones for a rad.
  2. sdluck
    sdluck
    Ask your rad shop,we have no way of knowing what it is or what shape it is in
  3. 325w
    325w
    from texas
    was told years ago by a radiator guy the stock style like the tri five chevies couldn't hold that much pressure because of the way they were made.
  4. Don task
    Don task
    Maybe I have to buy the expensive one.
  5. rtp
    rtp
    I am running the original rad.in my 48 old's cooling a 350 old's motor with the 6cyc.rad. had it cleaned out and re soldered . make sure you have a fan shroud .
    We pull a camper to the mountains in September and no over heating.
    Sent from my VS987 using The H.A.M.B. mobile app
  6. sdluck
    sdluck
    My model a has the stock style rad,my rad guys said to keep the cap 13 pounds or under.
  7. Don task
    Don task
  8. PhilA
    PhilA
    Just keep an eye open for cracks appearing, that's a lot of repeated flexing for the standard honeycomb type core.
    Mine had several cracks in the top tank and that's from the standard 7psi cap.
    Phil
  9. 54vicky
    54vicky
    what honeycomb?
