49,50,51 Lincoln owners?? Pic thread??
Discussion in 'The Hokey Ass Message Board' started by cfnutcase, Mar 12, 2009.
  1. cfnutcase
    cfnutcase
    from Branson mo
    Looking at buying a 51 lincoln, can you share some of your pics of them? Cosmos or the "baby" lincolns. thanks, Jim:D
  2. cfnutcase
    cfnutcase
    from Branson mo
    Come on, someone on here has to own a lincoln!!!!! Or am I looking at a true 1 of 1 car????LOL Jim
  3. I work on one every day...
  4. Rikster
    Rikster
    Who told you could leave your garage Per.... get back working on your car!
  5. Hey Rik, does your love of Mercs extend to baby lincolns?
  6. Rikster
    Rikster
    Absolutely. I love 49-51 Lincoln's. I love the longer wheelbase.
    Per (RPW) is building a very nice one
  7. Dick Dake
    Dick Dake
  8. 49 lincoln
    49 lincoln
    from reno
    I think there was an older thread on this...I've since lost my collection of photo's but I still have these: 744517083_m.jpg
  9. 51 MERC-CT
    51 MERC-CT
    How about this rare '49 Cosmo.:)
  10. signal_11
    signal_11
    My friend's mild custom Lincoln coupe:
  11. A custom-Cosmopolitan, this one is from Finland.
  12. petu54
    petu54
    from finland
    Other Kustom from Finland
  13. Ace Brown
    Ace Brown
    from OH
  14. attitudor
    attitudor
    from Finland
    That's Johnny Puuma's on HAMB.
  15. ROADRAT EDDIE
    ROADRAT EDDIE
    from New york
    A friend of mine...For sale btw
  16. MIGHTY
    MIGHTY
    Here is mine, Originally Built by Pat Walters. Now slowly being re-built by me.
  17. 49 lincoln
    49 lincoln
    from reno
    ^^Whatchya re-doing?^^
  18. MIGHTY
    MIGHTY
    Well car wasn't very road worthy when I got it. All shock mounts and Bag mounts were cracked. They have all been re welded. Front A-arms replaced Shock waves up front. New air comps, replaced re wired re mounted properly. New air lines.This car had no throttle response. It literally would not get out of its own way.The throttle arm for the Six rochesters had to be re fabricated & re located. New accelerator pumps.Lots of little things were done a bit wacky and a bit risky. One thing at a time. Had some electrical problems. Fixed those, almost burned her up! She needs interior and new paint to be satisfactory in my book but at least she is a cool cruzer now. Like I said one thing at a time.
    Peanut 1959 likes this.
  19. MIGHTY
    MIGHTY
  20. Carb-Otto
    Carb-Otto
    from FINkLAND
  21. jerseymike
    jerseymike
    just wondering, are lincoln and merc noses interchangeable?
  22. Squablow
    Squablow
    The frames are different due to the Lincoln wheelbase, so if you put a Merc nose on a Lincoln you have to shorten the frame, if you put a Lincoln front clip on a Merc, you'd have to make it longer.
    I want to put a Mercury front clip on my Lincoln, since it's hit in the front anyway, but I'll need a Mercury frame also.
    But bodywise, not including the frame, yes, they are interchangeable.
  23. Jive-Bomber
    Jive-Bomber
    MODERATOR
    The big Lincolns (Cosmopolitan) look good with a chop and cleaning up the stainless around the windows. I never saw another '49 Cosmo coupe like mine- most were the 'Merc' body, or 4 doors:
  24. update on mine.
  25. john worden
    john worden
    from iowa
    My avatar 51 survivor built in the 50s now with Appleton 112s 102_2041.JPG 102_2040.JPG 102_2043.JPG
  26. Not interchangeable at all. The Lincoln chassis is 5 inches longer from the firewall forward.
    None of the sheetmetal forward of the firewall will swap with Merc or Lincoln.
    The suspension is different as is the Engine, trans/gearbox and rear end.
    Not to mention a million other trim pieces etc.
  27. youngdrivinold
    youngdrivinold
    from Central FL
    Hence "(for the most part)". You could swap the body panels if you wanted to unless you're staying with the original ones (as in my case). The Cosmo was 5 in longer yes hence it being on its own separate chassis. Technically you are correct though, all were different part #s.
    Here are some pics.....on the trailer is before the body came off. Currently in the process of transplanting a 98 mustang GT drive train plus a M-II front end. Her flatty only ran on 5 cylinders when I received her but the Hydramatic shifted gooooood.....so I'm quite anxious to get her back on the road! 20150530_102624.jpg 20151126_224311[1].jpg .
