Projects 48 ford sedan to business coupe
Discussion in 'The Hokey Ass Message Board' started by NewGuyOldFord, Nov 17, 2016.
  1. NewGuyOldFord
    NewGuyOldFord
    Ok guys, I'm on the lookout for a 94-95 mustang t5 bellhousing. There has to be someone it there that stripped one for the engine but not running the stick shift with it. Any help would be appreciated. BART.
    Sent from my SM-N950U using The H.A.M.B. mobile app
  2. NewGuyOldFord
    NewGuyOldFord
    Squablow, scotts52 and LBCD like this.
  3. NewGuyOldFord
    NewGuyOldFord
    So, my friend showed up with his new Eastwood SCT drum sander and I let him loose on the "Kemp". Needless to say, I was quite impressed at how it turned out with the short amount of work. Here's some progress pictures. [​IMG][​IMG][​IMG]
    Squablow likes this.
  4. topher5150
    topher5150
    Any pics of the wedding from the inside
    Sent from my XT1254 using The H.A.M.B. mobile app
  5. NewGuyOldFord
    NewGuyOldFord
  6. topher5150
    topher5150
    Stupid phone.... Welding I meant to say welding
  7. NewGuyOldFord
    NewGuyOldFord
    I didn't put the new quarters on yet. He just cleaned it down to where I'm going to cut the new quarter on. I'll get some pictures of the inside once I get the floors welded to the new rockers. I'm an amateur compared to most on here so my work may be lacking in comparison.
  8. Squablow
    Squablow
    What does the drum sander look like? How long did it take to do that? I have not heard of that tool but I'm interested to hear more. Also, glad to see this car is still coming along, progress looks good!
  9. topher5150
    topher5150
    I thought you did or did you just set it into place
  10. NewGuyOldFord
    NewGuyOldFord
    I just set it in place. The side showing the sanding just has a bandaid and some tape to make sure my body lines are lined up from mating the two bodies together.
  11. NewGuyOldFord
    NewGuyOldFord
    Squablow, here is the tool he used. He stripped the door to bare metal in about 25 minutes and the quarter in about 30 minutes using different abrasive drums. [​IMG]
    Bam.inc and Squablow like this.
  12. NewGuyOldFord
    NewGuyOldFord
    So I did my first cut in of my new EMS quarter panel and I must say they are a top quality piece. The nicest thing on my cobbled together mess. [​IMG][​IMG]
  13. Squablow
    Squablow
    Thanks for the info! First I've ever heard of that tool. Also glad to see your patch panels are fitting up nicely.
  14. NewGuyOldFord
    NewGuyOldFord
    Squablow, I just stripped a 48 front fender tonight in 20 minutes. Tool works great.
  15. NewGuyOldFord
    NewGuyOldFord
    I got some more sanding done today with the Eastwood sander. It does a really good job and very easy to use. [​IMG][​IMG][​IMG]
  16. dave lewis
    dave lewis
    Same tool at lowes..
    Made by porter cable..
    100 bucks..
    Sent from my SAMSUNG-SM-G891A using The H.A.M.B. mobile app
  17. NewGuyOldFord
    NewGuyOldFord
    Either way, the style of tool works very well. Thanks for letting me know that there is a cheaper version. This tool is a friend of mine.
  18. NewGuyOldFord
    NewGuyOldFord
    I know I've seen this on here but I can't find it anywhere. What outside door handles do you use if you are deleting the side trim? I think it was 37-38.... right?
  19. NewGuyOldFord
    NewGuyOldFord
    scotts52 likes this.
  20. NewGuyOldFord
    NewGuyOldFord
    Took a quick break to cut up a 62 comet 4 Dr. It was pretty solid but wrecked in the driver's rear quarter. [​IMG][​IMG][​IMG][​IMG]
  21. NewGuyOldFord
    NewGuyOldFord
    Does anyone have any pictures of what the compartments looked liked behind the front seats in s business coupe? I'd like to see some to get an idea of what I could do back there. Thanks.
  22. NewGuyOldFord
    NewGuyOldFord
    Got the quarter pretty much mocked up to where I'm happy and can start welding. Don't worry about the wheel due to its a 4 lug comet rear I threw in it to move it around.[​IMG][​IMG][​IMG][​IMG]
  23. Squablow
    Squablow
    It is fully a coupe now!
  24. NewGuyOldFord
    NewGuyOldFord
    Thanks Squablow. It's not the standard of work that most do on here but it's turning out pretty good for my limited skill set.
  25. magoozi
    magoozi
    from san diego
    I have a lot parts for your project you can have cheap, the drawback is that i am in califorinia , i have a pretty decent deck lid, a lot of coupe garnish for buiness coupe and club coupe, a cherry 46 to 48 merc front clip, if you still need any parts , call me at 619 735 2674 or send me your phone number and i can call you
    Thor1 likes this.
  26. Rickybop
    Rickybop
    from Michigan
    NGOF... about rust removal.
    I've been using citric acid lately for rust removal. Does a very thorough job and isn't problematic like sandblasting or other acids. So far, I've only used it for small parts and tools that I can fully immerse in the water and citric acid solution. But I read that somebody was experimenting with using it on body panels by thickening it. I forget the thickener used... cornstarch? And then covering it with cellophane to keep it from drying out. It leaves a thin dark grey or black coating that's easily removed. You can find citric acid in powder form in the baking aisle at the grocery store. Larger amounts can be purchased from baking supply stores.
    Sent from my VS835 using The H.A.M.B. mobile app
  27. Rickybop
    Rickybop
    from Michigan
    BTW...
    Parts need to be rinsed in a solution of baking soda and water after rust removal to neutralize the acid. And then rinsed with plain water.
  28. NewGuyOldFord
    NewGuyOldFord
    Thanks magoozi and Rickybop. I'd be very interested in the citric acid ratio. All my other panels(fenders, doors, hood etc)are in good shape. It's just the rear quarters and roof.
  29. scrap metal 48
    scrap metal 48
    Coming along nicely. You have to feel good about the progress so far....
  30. NewGuyOldFord
    NewGuyOldFord
    Well, I made some progress on the car lately. Got the quarter tacked in place and the lower front wheelhouse fabbed up. It's not show quality but will do for the kind of car I'm building. Also put at 5 lug rear in so I can put wheels on it that I intend to use eventually. 20180428_135220.jpg 20180428_135214.jpg 20180429_103226.jpg 20180429_111811.jpg
    Squablow and Thor1 like this.
