Finally got the stylemaster on the road.......the steering box has a lot of play -like scary amounts,The book I have is very basic as far as repairs and isn't to clear on how to tighten/adjust it.Its on a 48 stylemaster.Was wondering if any one had clear instruction w/ pictures?I just did king pins(had machine shop do them)and new sway bar ends and bushings-soThe steering box is next-If I cant adjust it well enough,where can I get a replacement-thanks
There are 2 adjustments: one is up and down freeplay on the worm gear. That would be needed if the steering wheel shaft can be felt moving up or down at the steering wheel. It's not likely. The other adjuster pushes the sector (pitman shaft) deeper into the worm. It is a slot screw with a jamb nut. Turn your steering wheel 1/4 turn to one side with wheels off the ground. Turn the screw in until you feel it get a bit snug. Turn the steering wheel back to center; there should be a very slight drag barely felt at the center. You really need to look at the pitman arm shaft first, to see if the lower bushing is worn out badly. See if the shaft is running true as you rock the steering wheel with tires on the ground; it likely will be worn out and flopping in the bushing.
thanks guys I will check that site out tonite and check the info you gave me f&j and get this figured out
Don't forget... make all steering box adjustments with the pitman arm disconnected from the box or the tie-rod. Adjustments made with a load on the box are not true.
Will do looks like I will need to remove my oil filter/housing bracket to get to it.It sits blocking access to it
Thaught I would update my progress ,installed pitman arm bushings and adjusted worm gear/steering box -all play has been removed.The oil filter does need to be removed to access the steering box adjustment,If you have a babbit style inline 6 it sit`s right on top the steering box
