Yes ... potter automotive http://www.cadillacperformanceparts.com/ It's called the Boogieman intake the top cover can be changed out and a blower bolted on at a later date. I think it retails for about $650
some guys were running 460 Ford intakes with adapters and some machine work maybe a 2x4 intake for a 460 ford might work anyway,...check cad500.com
A friend of mine running a 472 in an A sedan made a 2x4 intake from to carb adapters for a supercharger. He used a single 4 and a 2x4, flipped them bottom to bottom and only had to drill a few holes. Then bolted it to the top of the original intake. Makes an nice cheap 2x4 adapter.
I was on here a year or so ago and apparently got dumped... besides I'm too old to intro to anybody... but if you must... been stripin' since '59, street racin' since '57... had 231 cars so far... write stuff for magazines... draw pictures for people... nap a lot. If it don't cost a hunerd grand I ain't interested. Thanks for the hints on the Cad intake guys.... the motor is in a '55 stude p/u which is the push car for the '53 stude b-ville car.
I remember Street Rodder Magazine did a build of a 500 cu. in. a number of years ago and they used a very kool 2 four intake. I believe the company was called Torque Specialist's. I hope this helps ..............good luck and welcome to the HAMB!!
http://www.cadillacperformanceparts...7bafe67db0d42948/option,com_phpshop/Itemid,1/ has a very racy 2 4 intake www.cad500parts.com has adapters to Ford, a Cad tunnel ram, and NEW 3 2 BBL INTAKE.
