Technical '47 Ford - SBC 327 to Early Ford Transmission - Help Wanted
Discussion in 'The Hokey Ass Message Board' started by axle, May 13, 2021.
  1. axle
    axle
    from Drag City
    Howdy fella's. I'm working on a 1947 Ford Woodie - was an all original car. Customer wants Chevy for power , mated to the original Trans & Rear.
    I have an old Offenhauser aluminum Trans Adapter.
    I bought a 10" Ford Clutch from Early Ford Store, but having a Hell of a time getting the correct Pressure Plate. I have been sold various Pressure Plates (3 finger & diaphragm) but so far, they have ALL been incorrect. The main issue is that when the Pedal is engaged - the throwout bearing doesn't reach all the way to engage everything. ('47 Ford Trans has inspection plate to see).
    *Again, this was an all original running/driving car.
    Help with the correct part number / year / make Pressure Plate would be greatly appreciated.
    Thanks
    Royalshifter likes this.
  2. Ralphies54
    Ralphies54
    what flywheel?
  3. lake_harley
    lake_harley
    I've not personally done the SBC to Ford swap but I did study up on it when I thought I was going to do that a few years ago. Seems there's something magical about a '50 Mercury Pressure Plate maybe? Also, a longer throwout bearing unit. I guess in reality I might have not helped since it's all a faded memory, but I tried. :rolleyes:
    Lynn
  4. Ralphies54
    Ralphies54
    I did one about 55 years ago if I remember I used chev flywheel 48 ford p/plate and 48 disc and throw out brg.
  5. Atwater Mike
    Atwater Mike
    I did one in '58, used Chevy Schieffer aluminum flywheel, Ford disc and '50 Merc pressure plate and T.O. brg.
    Don't remember any such thing as a 'long' Ford T.O. brg., though.
  6. Ralphies54
    Ralphies54
    I belive the pilot brg was something special I got from Honest charlie's speed shop
    Atwater Mike likes this.
  7. axle
    axle
    from Drag City
    Chevy Flywheel
  8. axle
    axle
    from Drag City
    You actually might be on to something. This is the stock original '47 Throwout Bearing, and the darn thing is miles away from the Pressure Plate. I'm wondering if there is a special extra long Throwout Bearing that I am supposed to use? Hmmmm. We even took a Pressure Plate out of another customers SBC/Early Ford combo , stuck it in there, and no bueno. I really appreciate all the comments and thoughts. Please keep them coming.....
  9. anthony myrick
    anthony myrick
  10. axle
    axle
    from Drag City
  11. anthony myrick
    anthony myrick
    Says to use the stock one
    ottoman and axle like this.
  12. lake_harley
    lake_harley
    I did some more searching on the topic and the thing I see mentioned over and over is the '50 Mercury Pressure Plate. Perhaps it's thicker than the 10" Ford Pressure Plate? Wish my memory was better and could be of better help.
    Lynn
  13. tub1
    tub1
    from tasmania
    I used clutch and pressure plate to duity ford trans and re drill the chev flywheel , I used 9 in clutch nice and light in use, also you need a spigot bush that provides about 3/4 of a inch from the crankshaft , maybe you would call it a pilot bush as the ford front shaft goes through the clutch plate but dosnt engage with the crankshaft
  14. F-head
    F-head
    The 50 Merc 10”pressure plate has evenly spaced mounting holes and bolts right on to a SBC flywheel
    It also is Borg and Beck style, formatted for an early Ford throw out bearing
    The 50 Merc uses an early Ford throw out bearing unlike a 50 Ford or 51 Merc
    If you try to use a chev pressure plate the fingers or the diaphragm won’t clear the large early Ford input shaft and won’t work with the Ford throw out bearing
    If someone try’s to sell you a 10” Long style
    Pressure plate it’s Ford and not Merc
    HemiDeuce and kidcampbell71 like this.
  15. F-head
    F-head
    Here’s a 50 Merc Borg and Beck 78CE8DCA-1376-4713-BE6D-2E81864E1FA8.jpeg 8DBF848A-652D-4DB6-8929-63324938E410.jpeg vs a 10” Ford Long style
  16. axle
    axle
    from Drag City
    Thanks F-head. - I really appreciate this. Do you have a part number on that '50 Merc Pressure Plate?
  17. F-head
    F-head
    Sorry don’t have a part number. I was lucky and found one in my stash
    axle likes this.
  18. Big Al
    Big Al
    I think you can buy the Merc pressure plate from wilcap.
    Al.
    olscrounger and axle like this.
  19. wheeltramp brian
    wheeltramp brian
    Or c&g ford parts
    axle likes this.
  20. krylon32
    krylon32
    Alliance Vendor
    from Nebraska
    Contact Fort Wayne Clutch and talk to Lou. I think you need the Chevy flywheel with the Merc PP and the Merc throwout brg that clips on the fork? That's the combination I was told about years ago as best as I can remember.
  21. razoo lew
    razoo lew
    from Calgary
  22. krylon32
    krylon32
    Alliance Vendor
    from Nebraska
    The RAM diaphragm PP would be a better deal. The diaphragm PP I always used that worked with the early throw out brg was a NAPA CA 30 but it has the Ford mounting pattern.
  23. axle
    axle
    from Drag City
    Awesome. Great info coming in. MUCH appreciated!
  24. AngleDrive
    AngleDrive
    from Florida
    Some inspiration
    kidcampbell71 likes this.
  25. axle
    axle
    from Drag City
    UPDATE: I found and bought a brand new '50 Merc pressure plate. As stated prior, we bought a brand new Ford 10" clutch. We have a pilot bearing from Speedway. After re-installation, the throwout bearing barely touches the pressure plate when fully engaged. MORE INFO: The adapter is an old Offenhauser , and after speaking with the nice guy at Wilcap, he had us measure it. It's 4" deep, and we were told that there might of been 2 different adapters made in the old days. Most Offenhauser adapters are about 3 1/2" to 3 5/8" deep. I can't believe the luck we're having!
    QUESTION: Does anyone out there make custom throwout bearings?
    Thanks in advance, Axle
    Johnny Gee likes this.
  26. That suck's.
    axle likes this.
  27. axle
    axle
    from Drag City
    Could you measure the depth of your adapter? where it bolts to back of block - to where it bolts to transmission
  28. AngleDrive
    AngleDrive
    from Florida
    Will do in the AM
    axle likes this.
  29. AngleDrive
    AngleDrive
    from Florida
    Looks like 3 3/8ths. Pilot bushing is Speedway item #720-5000. Make sure if you buy an adapter that the dowel pin holes are the same size as Chevy dowel pins. If your anal check bolt circle hole with dial indicator on crank so as not to strain front bearing on transmission. Clutch is Mercury, rebuilt by Fort Wayne Clutch and flywheel is aluminum.
    Starter bolts to bell housing adapter and is off a '57 motor.
  30. Moriarity
    Moriarity
    SUPER MODERATOR
    Yup, I had a buddy that put a 283 in a 40 and he wound up with one of those 4 inch adapters. He had to switch it to one of the 3 3/8 deep ones for the same reason. I wonder what the 4 inchers were made for???
