Technical 47 Ford Flathead distributor specialist
Discussion in 'Traditional Hot Rods' started by James Mundstock, May 25, 2019.
  1. James Mundstock
    James Mundstock
    Firs for those reading this that served our country; thank you. I am looking for a distributor specialist close to Cincinnati, Ohio that knows Flatheads. My distributor does not have the advance I am looking for and I had it apart and everything is free moving. No hang ups. I spoke with Joe Abbin in Albuquerque, New Mexico and he said I should have 20 degrees advance but I am only getting 15 at best. Thanks in advance for the replies.
  2. mkubacak
    mkubacak
  3. Truck64
    Truck64
    from Ioway
    Thank them November 11th, Memorial Day honors those who were killed in combat. Jus' Sayin'.
    alanp561 and Jim Bouchard like this.
  4. 03GMCSonoma
    03GMCSonoma
    You are welcome.
  5. 51504bat
    51504bat
  6. alchemy
    alchemy
    I also had Bubba do one for me. Might want to have him convert the cap, rotor, and clips to '42 parts at the same time as they are much easier to work on.
  7. lake_harley
    lake_harley
    I can't speak with any authority specifically on the flathead distributor, but are you talking distributor advance or advance at the crankshaft? If you have determined that the distributor itself advances 15 degrees that would be a timing advance at the crankshaft of 30 degrees. If that's something you already had in mind when you posted the numbers please ignore my post.
    Lynn
