Projects 47 Coupe Build
Discussion in 'The Hokey Ass Message Board' started by oliver westlund, Dec 20, 2018.
  1. oliver westlund
    oliver westlund
  2. Slopok
    Slopok
    Before you go too far, Pc-7 is available at Ace, supposedly better than JB weld from what I've read and heard. Just sayin.
  3. oliver westlund
    oliver westlund
    too late, i had read they were comparable. i suppose if it fails i can always do it again! also just found some 1974 newspaper shoved in the drivers door above the window mech. i am gently pulling them apart, if i see anything interesting ill post pics
  4. oliver westlund
    oliver westlund
    well my car was in albany Oregon in 1974
    20190206_172904_resized.jpg 20190206_172846_resized.jpg 20190206_172932_resized.jpg 20190206_172829_resized.jpg 20190206_172723_resized.jpg 20190206_173019_resized.jpg
    chryslerfan55 and enloe like this.
  5. oliver westlund
    oliver westlund
    old broken collar is off, im going to leave the column shift rod but remove the part the actual shifter goes in so itll just be a straight rod. looks weird without the rod but looks like somethins missing if i leave the shifting collar
  6. oliver westlund
    oliver westlund
    little collar cleanup, I'm thinking black column, white collar, white wheel...unless thatll look weird? black dash, white tuck and roll seats with black inserts
  7. I used JB weld to repair a 39 ford banjo wheel...looked awesome so I painted it and stored it in the attic all summer. Pulled it out in the fall to see all the repaired spots were cracked! Never again!
    So, how did the Y-block run?
  8. oliver westlund
    oliver westlund
    i hope that doesnt happen! if it does ill fill em with pc 7 or whatever its called. i havnt fired the y block up yet. ive been assessing long and hard how i want to do it. the previous owners work is uh...interesting. i dont want to cause damage. ill get into it this weekend!
  9. oliver westlund
    oliver westlund
    i did give metal saver a try! that stuff works pretty good! idk if its any better than vinegar and water but i was pleased with the results
  10. oliver westlund
    oliver westlund
    with a 292 y block without much in the way of upgrades, should i be able to run my banjo, torque tube and a flattie standard floor shift trans?
  11. As long as you don't beat on it.... The Y-block has about twice the power of the flathead as OEM.
    oliver westlund likes this.
  12. oliver westlund
    oliver westlund
    Roger that...im thinking of it as a way to get it on the road while i rebuild my 394 olds and do a jeep shifter conversion on a toploader
  13. oliver westlund
    oliver westlund
    wetsand with 2k, cutting compound and carnuba wax! shiny enough for me! 20190211_130103.jpg 20190211_130405.jpg 20190211_130818.jpg
  14. s55mercury66
    s55mercury66
    from SW Wyoming
    Now, put 5 more on, polish, repeat.
  15. oliver westlund
    oliver westlund
    i dont want it too shiny! just shiny enough to sparkle a little in the sun haha
  16. oliver westlund
    oliver westlund
    can anybody walk me through how to bolt the stock guage pack on? i dont see any threads...also dont see how in the heck the trim piece that goes over em would stay put? HELP! haha
  17. oliver westlund
    oliver westlund
    also need to know what the heck these holes are? ive scoured tons of dash pics online and none of them have them!
  18. BamaMav
    BamaMav
    from Berry, AL
    If yours is like my Lincoln, there are studs in the back of the dash, you put the cluster in from the rear, and there are little bridge pieces that go on the stud, then put the nuts on. The bridges rest on the cluster on one end, the dash the other.
    I think the trim piece has studs that go through the dash, then a washer and nut to secure them. Just going from memory, and mine may be totally different than the Ford.
  19. oliver westlund
    oliver westlund
    no studs for me, here are more pics 20190211_173120.jpg 20190211_173127.jpg 20190211_173139.jpg
  20. BamaMav
    BamaMav
    from Berry, AL
    When I’m at home and get time (and remember to do it) I have some pics of mine being put together I’ll post. They are on the home pc, don’t have any on this iPad.
    Now I see the back of yours, it’s different than the Lincoln. You must have a chrome strip that runs in line with the gauges, looks like it would carry the studs to hold the assembly on. Mine has the little bridges like on your speedo on all the gauges IIRC.
  21. oliver westlund
    oliver westlund
    thank you!
  22. oliver westlund
    oliver westlund
    anybody recognize the holes by my radio?
  23. oliver westlund
    oliver westlund
    they seem too wide to be radio delete plate holes
  24. razoo lew
    razoo lew
    from Calgary
    I had to go look - damn but it is cold out there. My '46 dash does not have the holes on either side of the radio opening. Also FWIW, the opening in your dash looks to be a bit different shape than mine - likely something "different" installed there in the last 72 years.
    The "large" trim on mine (speedometer surround etc) is attached with small screws from the back, through the upper row of holes across the dash - like the one I am pointing at below.
    The guage cluster and guage trim is held on by screws from the back which hold the cluster to the trim through the dash, one of which is visible in the picture at the end of the guage cluster. (ran out of hands to point at it) Hope this helps.
  25. oliver westlund
    oliver westlund
    awesome!!! so helpful! so the guage cluster trim is supposed to have screw holes? i have two of them and niether has screw holes. my cutout is for a stock radio, i have test fit mine and it fits although there were 2 radio options i think could be a states vs canada thing. ill do a separate post for the weird holes
  26. razoo lew
    razoo lew
    from Calgary
    Ok. My guage trim is entirely different...
    Sent from my SM-A520W using The H.A.M.B. mobile app
  27. oliver westlund
    oliver westlund
  28. BamaMav
    BamaMav
    from Berry, AL
    My Lincoln dash is a bit different 100_1851_zps1b21fbb2.jpg 100_1849_zps299cfc7f.jpg 100_1850_zps69ecde52.jpg 100_2041_zps3d4efa38.jpg
    You can see the tabs on mine that the studs go through from the back.
  29. oliver westlund
    oliver westlund
  30. Ritzy1
    Ritzy1
    The original gauge trim on my '48 was also missing one of the studs that hold the gauges in. The one that was there looked like it had been re-attached with epoxy. Most of the replacement trim you see advertised on Ebay are missing the studs as they must have been poorly attached from the factory. I was able to source a replacement, although it's a bit bent where the studs are attached. One of the studs from my trim on the glove box side has also come loose, and I'm going to try to solder it back on. If you're looking for a new piece of trim try here: http://marksfordparts.com/contact/index.html.
