460 Ford???
Discussion in 'The Hokey Ass Message Board' started by ShortyLaVen, Nov 14, 2012.
  1. We were building a '72 Torino stock car many moons ago and we didn't think the tired 351W would cut the mouseturd. I stumbled on a '69 Marquis with a 429, so the die was cast. Pulled the heads off it, HUGE valves and ports and those combustion chambers. New gaskets and a Chet Herbert solid lifter cheater cam and we were set.
    By next season that was tired and a borderline junkyard motor from the start. A 460 was found and a made into a 496 stroker, nothing could catch it on the straights at Islip.
    milwscruffy likes this.
  2. Thanks for the help.
    UOTE="THE FRENCHTOWN FLYER, post: 11717397, member: 34137"]Just a ballpark guess with that stroker crank- 12.5:1
    It is impossible to accurately assess without knowing the compression height and dome volume, even if the combustion chamber of the D3VE- heads is stock.
    Knowing what the original builder's intentions for the engine was may shed a clue as to how much squeeze he put into it.[/QUOTE]
  3. Bore scope confirmed a large dome and .030 pistons. I may yank a head to do some measuring,
  4. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    Was the PO going to run it on alcohol? It may be higher than my original estimate. 14 - 15:1???
  5. No clue, this coming week I think I'll pull the heads and see what is what. I'll post pictures once their off. At least that way I can confirm bore size along with the dome size. I heard the builder at one time had a 10 flat F 150 , so at this point all bets are off until I can confirm more parts.
  6. RmK57
    RmK57
    underside of the piston should have a part#......maybe.
  7. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    I have been successful making a mold of the domes using plaster to get the cc's. Make a dam around the land using masking tape and fill with plaster; when it hardens spray the inside with paint and fill with fluid to measure the cc's. Might as well measure the deck height clearance while you're at it.
  8. drtrcrV-8
    drtrcrV-8
  9. drtrcrV-8
    drtrcrV-8
  10. boo
    boo
    from stuart,fl.
    my buddies and i have had a few 460 engined cars,, just buy a 69-71 linc mark 3 for 3-400$ pull the eng and 375 hp w/c-6 cheep, no wild cams or carbs. i have one in my 34 5w now w/boss 9 heads, cool looking, great motor. have stuff to build 2 boss 9 engs. if interested...
