1946 Ford Super Deluxe Coupe, original body with suspension and motor upgrades. Up front is a 4” drop magnum I-beam axle, drop steering arms, and a Posie superslide front drop spring. Pete and Jakes disc brakes and hot rod shock kit to finish out the front. Rear suspension is TCI parallel leaf kit with a rebuilt Grenada 8”. Transmission is a ford floor shift 3 speed with open drive shaft. The motor is a V8 flathead with a dual carb offy intake and two rebuilt 94’s on top. Car is converted to 12V with electronic ignition. Dualed out exhaust all the way out the back. Good solid body, little rust in trunk, rockers, and driverside drip rail. Asking 9,500. No Trades. Call/text 615-587-1293 or email [email protected] to inquire.
