Technical '46 ford, no room for radiator
Discussion in 'Traditional Hot Rods' started by 1oldhotrodder, Sep 29, 2019.
  1. 1oldhotrodder
    1oldhotrodder
    I have put a 351W in a '46 Ford and have the usual problem of not enough room for the radiator. Does anyone have a simple fix to move the radiator forward a couple of inches?
    Thanks for any help
  2. Budget36
    Budget36
    I wonder if there was a different radiator mount for a 6cyl vs 8cyl?
    1oldhotrodder likes this.
  3. Tim
    Tim
    from Raytown Mo
    Yes there is a different radiator set up for the 6 cylinder cars and it gains you a couple inches.
    Post some photos of what you have and we might have some ideas
  4. Jalopy Joker
    Jalopy Joker
    yes, need pics - been a while but, believe that I used a '67 Mustang radiator in my '47 with a 302, which is thinner than a stock radiator also, check speewaymotors.com for their shortie waterpump kit for 302-351
  5. sloppy jalopies
    sloppy jalopies
    try a Modine #397 …
    trapaziodal top tank that is center fill... pre-'70 ford and sbc ports …
    fits in a '28-'29 grill after removing most of the good size mounting flanges on each side...
    think it came from a '67 ford 6 cyl. pick up truck... both ports are slightly smaller...
    a mechanic buddy runs them in everything he builds … cools his sbc's...
    brass … $125 for him... $152 for me...
  6. topher5150
    topher5150
  7. 6sally6
    6sally6
    Yes....SBF Have DIFFERENT length "snouts" on their water pumps.
    Don't axe how I figgered this out!!!!
    6sally6
  8. 1oldhotrodder
    1oldhotrodder
    Thanks to all who replied. I have a few things to try now....
  9. I have a 351w in my 47, walker radiator fits in stock location.. a little over 2” from water pump flange to back of radiator. Using a pusher fan for cooling.
  10. LM14
    LM14
    from Iowa
    Cheap and easy stock parts to make it as short as possible.
    Get the aftermarket timing cover Speedway sells. Very nice copy of a 1971 timing cover. Put a '69 water pump for a Galaxie on it. That gets you a right hand outlet so you can use a Chevy radiator (cheaper). If you already have a Ford outlet radiator go to a '71 water pump. Use the Speedway chrome cheapo pulleys.
    If you have a 3 bolt balancer it's no problem, if you have a 4 bolt balancer you will need to swap to a ProProducts balancer with the correct imbalance (Speedway also has them). They have both 3 and 4 bolt patterns in them.
    I also use the Speedway cheapo chrome alternator mount kit and it tucks the alternator in tight on the right side. Works best on a 302/5.0 but is easily modified to work on the taller Windsor.
    You can use any of the 3 timing sets marked on the Pro Products balancer. I like to use a straight stud with a point ground on it screwed into the timing cover hole about 2:00 as you look at it from the front. Easy to see.
    SPark
    clr7.jpg clr8.jpg clr9.jpg clr10.jpg assembly2a.png assembly2b.png assembly2e.png
    Texas Webb and Budget36 like this.
  11. Those are great tips. I’ve run the drivers side lower hose on mine for years but when I added power steering and subsequent pump to it this spring, I had issues getting hose to fit as the belt runs very close to it. The narrower radiator makes for a quick turn back from the engine, rather than the wider radiator used in the 70’s.
    If you’re planning on power steering, look into lm14 s suggestions and pictures above.
  12. a boner
    a boner
  13. 1oldhotrodder
    1oldhotrodder
    Thank you LM14. The best solution that I've seen. The pics are a great help.
  14. Bruce Lancaster
    Bruce Lancaster
    And on an older suggestion up above...if you remove the piece of tin that forms a lid over the area between standard V8 radiator and the hood latch, you will be able to see the groove and bolt holes for the mounts of the 6 cylinder radiator. They give a considerable amount of extra room.
    But all in all, late model Ford engines are just plain a poor fit and ugly as sin in Flathead era Fords. Sorry, no way around that!
    Chevy engines seem to have been designed as replacements for flatheads.
  15. JeffB2
    JeffB2
    from Phoenix,AZ
  16. Bruce, you got that right, the sbc's dimensions are very similar to that of the flathead V8. HRP
    weps likes this.
