What do you guys think a complete intake to pan running 76 455 Olds motor is worth? With exhaust manifolds, PS, A/C and alternator brackets. Thanks much.
$500.00. The 76's were getting low on compression. The block is the same, but the heads are smoggers. Pistons are pretty dished too. Heads are probably "J" heads, which are pretty restrictive. Don
A lot to any of the guys that left water in there Flat bottom over the winter. I see them every spring and cores are getting scarce.
