Technical 455 buick exhaust manifolds
Discussion in 'Traditional Hot Rods' started by 410merc, Jun 16, 2017.
  1. 410merc
    410merc
    hello everyone , i'v been putting a 455 buick in my modal a ford , and I run into a snag ,the passenger side manifold sticks out so far to the side at the rear of the engine , so here 's my question did buick ever make any other type manifold , I don't want to build headers if I don't have to , I need ideas
  2. Engine man
    Engine man
    from Wisconsin
    I don't know for certain but I assume it was turned out to allow for the automatic transmission dipstick and air conditioner box. Maybe somebody else knows. Could it be cut and welded to turn it down?
  3. gimpyshotrods
    gimpyshotrods
    Get someone else to build you headers.
  4. Engine man
    Engine man
    from Wisconsin
    410merc likes this.
  5. Stonebird
    Stonebird
    The above chart shows a 68 400/430 being different. This is a 68 430 out of an Electra in my build. Best pic I have of it right now. Don't know if you can see enough to tell if it is different. I can get a better pic of it tonight if that would help. Let me know what angle you need to see it from. I guess I also have a 455 at home too, I could see if I can tell if there is a big difference.
    410merc likes this.
  6. Stonebird
    Stonebird
    First pic is 455. Heater box makes it hard to see much. Other 2 are the 430. I couldn't tell much difference from the view I have. Hope this helps.
    410merc likes this.
  7. southcross2631
    southcross2631
    Try a driver side manifold on the pass. side so it exits forward.
    I don't blame you, I would not want to build headers. Better performance , cooler looking, what a hassle.
    tfeverfred likes this.
  8. Stonebird
    Stonebird
    IMG_0563.JPG If you can zoom in on this pic I suspect the drivers side would exit right into the motor mount. Do you have room to offset the engine to the driver side?
  9. 410merc
    410merc
    that's just what I thought , it would be so much simpiler this way
  10. 410merc
    410merc
    oh ,thankyou so much , I think it helped ,my manifold has part no 1383648 and that makes it a 68 -430 manifold ,but for some reason mine sticks out way more than yours ,I wonder what manifold you have
  11. 410merc
    410merc
  12. Stonebird
    Stonebird
    Mine came out of a very low mileage 68 Electra so it should be the original manifold. Maybe it's camera angles making them look different.
  13. right side manifolds 455 430 - 1238094
    1238054
    1383648
    cheaper to make up a set of headers, start with a used set of headers for the flanges, get shorty SBC headers and combine them.
  14. 410merc
    410merc
    tried that I'm into the motor mount bigtime if I switch sides
  15. sdluck
    sdluck
    Take a header gasket and see if it is close to any other gasket.
  16. southcross2631
    southcross2631
    You do know you can cut and reweld cast iron exhaust manifolds ? I couldn't find a right side manifold for an original Boss 302 Mustang and the 351 Cleveland manifold I had hit the bellhousing . So cut a notch in it and welded it back up. Looked factory until you took it off and turned it over . Used my stick welder and nickel rod.
  17. ididntdoit1960
    ididntdoit1960
    from Western MA
    is there enough clearance to angle mill the manifold to tip it in some....
