454 chevy intake ??
Discussion in 'The Hokey Ass Message Board' started by midnight auto parts, Apr 4, 2009.
  1. midnight auto parts
    midnight auto parts
    from tn
    i have a 1981 chevy crewcab dually with 454 and want to change intakes. the engine is stock and the truck is a four speed-four wheel drive. i need advice on what would be a good intake to use. i pull my trailers with this truck so low end torque is what i am after.
    [​IMG][​IMG]
  2. draggin'GTO
    draggin'GTO
    Put an Edelbrock Performer on it.
    1500 to 5500 RPM range.
  3. Edelbrock SP2P. It is a dual plane torque intake.
  4. 55ledsled
    55ledsled
    from Amarillo
    Professional Products Cyclone....Comparable to both of the above Edelbrocks but can be found a bit cheaper....Yes, its made overseas, but the quality is decent...If you are a USA all the way kinda guy, then never mind...
  5. hillbilly4008
    hillbilly4008
    from Rome NY
    im running a '86 454 in my truck. Since i wanted to get rid of the EFI and pollution crap i installed a 396 intake i had laying under the bench. So i guess an intakes an intake as long as its not off a 348 or 409.
  6. wetatt4u
    wetatt4u
    hillbilly4008<SCRIPT type=text/javascript> vbmenu_register("postmenu_3781886", true); </SCRIPT>
    I did not think that a BB 396 intake would match up And fit onto a BB 454 engine ?
    HUH !
    I always thought that the 454 was wider!
  7. hillbilly4008
    hillbilly4008
    from Rome NY
    In my case it def. works. The 454 came out of an '86 1ton dually, square ports. Im not sure where the 396 intake came from, my father pulled it 20+years ago. Knowing my father it was most likely off a chevelle. What i did was ran the part #s for the intake gaskets off the 454 and part #s for intake gaskets from a '70s 396 before i pulled the intake off. They are identical. Boy was i stoked when i found that i didnt have to go out and buy a new intake.
  8. hillbilly4008
    hillbilly4008
    from Rome NY
    i really wish i could get better pictures, but these are the best i have at the time being
  9. phat rat
    phat rat
    396, 402, 427 and 454 all take the same intake. The only difference is whether the heads are square or oval port.
    I did forget one thing. If it's a tall deck the intake won't fit
  10. rq375
    rq375
    from Washington
    Tall deck will be 366 or 427, they still take the same intake, but you put spacer plates on the heads for it to work.
    for the OP: Weiand action plus or standard performer, vacuum advance HEI, and a quadrajet.
