41 plymouth question !
Discussion in 'The Hokey Ass Message Board' started by THOMAS31, Oct 27, 2010.
  1. THOMAS31
    THOMAS31
    from DALLAS Ga,
    Hey guys, Tommy here owner of Moore's hot rods in Dallas Ga. Some of you already know me but most of you dont.
    I read on here more than I write, this time I could use a little help if you will. I have just picked up a 1941 plymouth business coupe and looking to do alittle up grade to the rear by changing the axle out to a more modern one and dont have alot of time to search around for the best fit . Any help would be appericated.
    thanks T.M
  2. 73RR
    73RR
  3. THOMAS31
    THOMAS31
    from DALLAS Ga,
    lol its not , but when you dont have anytime to get to a junk yard before they close and most wont let you go in to search it makes it hard ! but thanks for the info .
  4. hotrodjohnny77
    hotrodjohnny77
    Ford 8.8 out of a Mustang or Explorer will fit.
    Jon
  5. THOMAS31
    THOMAS31
    from DALLAS Ga,
  6. George
    George
    68 C body is a bolt in.
  7. Frankie47
    Frankie47
    from omaha ne.
    just about any B body.
  8. THOMAS31
    THOMAS31
    from DALLAS Ga,
    thanks George & Frankie !!
  9. 73RR
    73RR
    Thomas, I provided the chart so you could actually find one that fits. Frankie says use any B body, however, B body assemblies can vary up to 5" depending on year and application...:D
    ...and the Mustang rear varies depending on year.
    Here are more Ford numbers:
    65-66 Mustang 57.25 inches
    67-70 Mustang 59.25 inches
    71-73 Mustang 61.25 inches
    77-81 Versailles 58.50 inches
    67-73 Mustang, Torino, Ranchero, Fairlane 9" 59.25 inches to 61.25 inches
    66-69 Torino, Ranchero, Fairlane 67-70 Mustang 59.25, 70-71 Torino 71-73 Mustang 61.25
    57-59 Ranchero and station wagon rears, 57.25 inches
    66-77 Bronco 9", 58 inches
    77-81 Granada/Versailles, 58 inches
    67-71 Comet, Cougar, Mustang, Fairlane, 59.25 inches
    66-69 Comet/Fairlane 67-70 Mustang/Cougar 59.25 inches
    71-73 Mustang, 61.25 inches
    64 Falcon 58 inches
    67 Cougar 60 inches (68-70 Cougar 59.25)
    67 Fairlane 63.50 inches
    72 Ford Van 3/4 ton 68 inches
    73-86 65.25 inches
    57-59 Ranchero and station wagon 57.25 inches (narrowest 9" housing)
    66-77 Bronco 58 inches but has 5-on-5 1/2 inch diameter bolt circle
    67-73 Torinos, Rancheros, Fairlanes 59.25 inches or 61.25 inches 66-69=59.25 70-71=61.25
    67-71 Comets, Cougars, Fairlanes 59.25 66-69 Comet/Fairlane , 67-70 Cougar 59.25
    79-93 Mustang 7.5 and 8.8 57 inches
    Lincoln Mark7 LSC, SVO Mustang and Fox Body Saleens use a 59.5 inch wide rear axle
    94-98 Mustangs use a 58.5 inch wide rear axle
    99 and newer Mustangs use a 59 7/8 inch wide rear axle
    __________________
    [​IMG] <!-- / message --><!-- sig -->
    Let us know what you find and how it works out.
  10. 36DodgeRam
    36DodgeRam
    I put a '79 Trans Am 10 bolt posi in my '40 Plymouth business coupe. Perfect fit in width and dropped right onto the stock springs, no mods required. '69 Chevelle driveshaft was perfect length too, no cutting.
  11. THOMAS31
    THOMAS31
    from DALLAS Ga,
    now this is why I like this site , you guys are a big help ! thanks for the info guys !!!!
  12. 73RR
    73RR
    The big issue with a gm rear is the bolt pattern for the wheels.....:cool:
  13. THOMAS31
    THOMAS31
    from DALLAS Ga,
    the bolt pattern is no big deal ,Ive changed the factory 16" wheels out to 15" universal bolt ford or chevy. but thanks for the heads up 73RR !
  14. Frankie47
    Frankie47
    from omaha ne.
    I made an assumption since I have seen a Charger rear end in a p-15....my bad:eek:
  15. rockable
    rockable
    I used a rear from an '88 Dakota. The '87-90 models had 5 lugs, if I remember correctly. This has drum brakes. The Ford Explorer rear is easier to find, cheaper and has disc brakes. If I were doing it again, I'd find me an Explorer rear.
  16. I've seen that Plymouth and talked with you about it. I'm just down the road from you at Rockmart. Beautiful car, amazing to find one that solid and well-preserved.
  17. Hemi8me
    Hemi8me
    Interesting. Where are they measured? Hub to hub? Backing plate to backing plate? Do you have measurements for other rear ends?
    <input id="gwProxy" type="hidden"><!--Session data--><input onclick="jsCall();" id="jsProxy" type="hidden">
  18. 73RR
    73RR
    Everything is measured at the face of the hub/drum. As above, the Mopar stuff is here.
  19. Ratroddude
    Ratroddude
    I have a posi-rear out of a 1984 Dodge diplomat Ex-police car , complete with the big sway bars leaf springs , wheel to wheel , will that work? , keep it all Mopar.....
  20. Ratroddude
    Ratroddude
    By the way , if your looking to keep it all Mopar , I got everything you need , like a police interceptor v-8 , auto tranny , the rear I was telling you about , factory 8 inch steel wheels , the whole thing , PM me if your interested...
  21. 4woody
    4woody
    Don't Explorer 8.8's have the pinion offset? The Ranger 8.8 does, and wouldn't work in my '38 Mopar for that reason.
  22. Frankie47
    Frankie47
    from omaha ne.
    Good God, that is one GREEN engine.....Wish I had your police steelies though:)
  23. 41 d20
    41 d20
    how much is the offset ?
    i know putting in a 318 with stock steering you have to offset the engine 1'' to the passenger side also look here for more info
    http://www.carnut.com/specs/rear.html
  24. Ruiner
    Ruiner
    I've got a '61 Pontiac Powr-lok rear under mine...with 10" wide slicks it took some fender trimming ;)...
  25. sololobo
    sololobo
    Beautiful coupe man, good luck with the mods, keep us posted on progess. Looka like a nice survivor, one of my fave body styles ever. ~sololobo~
