Projects 41 plymouth coupe 392 hemi build thread
Discussion in 'The Hokey Ass Message Board' started by farmer12, Apr 7, 2010.
  1. HeyyCharger
    HeyyCharger
    What a fantastic build!
    The dimensions of the car are spot on!
    Really loving it!
    What power you getting out of the 392?
    Great work.
    HC.
  2. the DutchDude
    the DutchDude
    hell yeah,, strip that girl!!
    will save alot of trouble before paint,,
    you never know what's under all those previous coats,,
    now you have a the perfect base,,
  3. farmer12
    farmer12
    According to my engine builder, the 392 should produce 500 hp. I think that should be enough to light up the white walls!:D
  4. HeyyCharger
    HeyyCharger
    x 2!
    HC.
  5. SKOTY CHOPS KUSTOMS
    SKOTY CHOPS KUSTOMS
    from BAY AREA
    Man that sure is alot of relief cuts. By the time it took to weld all that you could have just made a panel.
  6. 55oldsrocket
    55oldsrocket
    from Santa Ana
    this is a great build. keep up the good work.
  7. farmer12
    farmer12
    Yes, I agree. That's why I'm rectifying it now, using only metal. Not sure if the previous owner had any experience in this kind of chop.......
  8. farmer12
    farmer12
    Thank you for the compliment. Still learning everyday.
  9. choppwatchagot
    choppwatchagot
    awsome work keep it up
  10. farmer12
    farmer12
    Thank you. More pics coming soon.:D
  11. farmer12
    farmer12
    Cleaned the frame today and working out now where to further strengthen it.Just want to make sure its all strong enough, may be a bit of overkill. Should get my gearbox tomorrow. From there I can work out the mounting position of the TKO 600 and do some more welding. Can finally determine the position of the engine mounts and get it all lined up. Will post some pics tomorrow. :)
  12. farmer12
    farmer12
    Got the TKO 600 today together with the bellhousing. Mocked up the bellhousing behind the engine, substituting the adapter plate with a 1 inch piece of wood. This will at least give me a good reference as to where I now need to make my transmission mount in the frame. Will start tomorrow with cutting the old mount out and getting some steel from my friend in order to strengthen the frame. Will post some pics of the frame soon.
  13. farmer12
    farmer12
    Here's some pics of the frame. Just wiped it down and only found some surface rust on the original parts. Nothing serious.
  14. farmer12
    farmer12
    Here's one more photo to give you an idea. Can't wait to work on it tomorrow.
  15. Bloody hell, thats some car for the Netherlands. Where,s your first test drive ? Schiphol ? :D.
  16. farmer12
    farmer12
    A good friend of mine is an air traffic controller at Schiphol. If only there would be another volcanic eruption in Iceland early next year........
  17. farmer12
    farmer12
    Attached the transmission behind the mock up engine in order to determine the position of the mount. Time to get me some steel!
  18. farmer12
    farmer12
    All right! First of all I cut out the old tranny support.Got some steel and started measuring and measuring. Cut the steel bar so it will fit over and between the frame for added support. It warped slightly but I will ensure it will be welded perfectly straight. Pretty happy how much you can achieve in a few hours, even for a beginner. The new piece will not only support the gearbox but also make the frame more rigid. Going to cut up some more steel tomorrow for added strength and looks of course!
  19. farmer12
    farmer12
    Got a lot done today.Started with the sheet metal to cover the top and inside of the frame. This took quite some measuring.I'll post the sheet metal pics tomorrow when the welding starts. Now the reason I'm only doing this section of the frame ,is that later it will be very difficult to get some rust protective paint in these small and covered places. I then cleaned the section, which was covered with surface rust and dirt in all corners. Then applied a few coats of anti rust primer and finally with anti rust black gloss paint. A lot of work, considering I'll probably never see it unless I'm under the car with a torch. Then again, peace of mind knowing this was tackled is also worth something.:)
  20. Church
    Church
    from South Bay
    You win.
    Man that thing looks pissed off standing still.
  21. farmer12
    farmer12
    Now you can understand that it was "love at first sight". Knowing that a lot of work had to be done, did not worry me in the slightest. I just knew I wanted this car and make it better than ever before. No regrets so far!! Glad you like it.
  22. 1959apache
    1959apache
    Are you still thinking about putting big fat white walls on that pig? Good progress so far, keep it up dude. I am itching to get my pickup running so I can start working on my plymouth again... you are the cause of the twinge. lol
  23. farmer12
    farmer12
    Thanks for the compliment. Yes, still going for the whitewalls, gotta make them scream!!Good luck with the pick up/plymouth!
  24. I just now saw this thread - way cool project! I love the look of that car and the fact that you're putting a big ole' 92 in it makes me proud of yah. If you have any challenges with the clutch/tranny setup, let me know . . . have done extensive work in this area. Are you using an adapter and flywheel combo from Pat at Wilcap? Hopefully so - he makes about the best product there is for this.
    What cam are you running in the engine?
    Dale
  25. farmer12
    farmer12
    If you're going to it right ,you need a 392! Adapter and flywheel are from Keisler engineering. Using a Quick Time bellhousing with a Keisler TKO 600 5 speed behind that.(Using a hydraulic clutch) If I need any help I'll certainly let you know. Camshaft is a mild cam, don't know the exact specifications.
  26. farmer12
    farmer12
    Once again, got a lot done today. Painted the rest of the sheet metal(underside). Once again my friend Jaap came along to do the welding part. First was the transmission member, then welded all the sheet metal. This will give a nice clean look when looking in the engine bay, considering there is an inch and a half between the body and chassis. Finally cleaned up the welds. Will clean it all tomorrow and put some primer on it.
  27. farmer12
    farmer12
    Thanks! Really enjoying the fact that the progress is going so well without any major obstacles.
  28. farmer12
    farmer12
    Good to hear from you again! I certainly won't mind if you start your thread. (maybe I can learn something:)) Wouldn't mind seeing some pics, good luck with your build.
  29. farmer12
    farmer12
    You and me both! Thanks for the kind words.
