Projects 41 olds rear needs to go lower....
Discussion in 'Traditional Customs' started by Olds Tinman, Jun 2, 2019.
  1. Olds Tinman
    Olds Tinman
    from W.N.Y
    I know this probably been brought up 100s of times.. how do I lower my rear coil springs.... the clamps on springs only took down like a 1” do not want to use heat... any old tricks? Thanks guys
  2. oldsman41
    oldsman41
    You can cut the springs go a little at a time doesnt take much. My 41 is on coilovers now but i had it pretty low before i put a different motor trans and rear in it.
  3. Are the coil springs pig tailed or straight top to bottom.
    You can look in the Moog catalog and find a spring from a modern car that fits but is shorter.( I found 80’s regal springs worked in my 55 Buick)
    I have heard of guys cutting pig tailed spring and making a large cup that can be bolted down to hold the spring in place.
    Those spring clams deals are junk and not worth the aggravation.
    Crazy Steve likes this.
  4. Olds Tinman
    Olds Tinman
    from W.N.Y
    They are pig tailed I was thinking of a cup to have them sit on..
