'41 ford 1/2 ton rear-end
Discussion in 'The Hokey Ass Message Board' started by north coast greaser, Mar 18, 2007.
  1. i am looking at picking up a '41-ish 1/2ton ford rearend for the RPU, and want to do an open drive conversion. i checked out hotrodworks and they seem to have 2 different kits. one for a 6 spline and 1 for a 10 spline rearend. which kit would work for the '41 truck rear?
    i'm not sure if the truck is a V8 truck or a 6-cylinder truck, (theres no motor in it) also, would a stock 1/2ton rear be strong enough with a 2.3L banger with auto tranny in front of it?
    thanks
    ncg
  2. HotRodWorks
    HotRodWorks
    Alliance Vendor
    If it is a 1/2 ton with a torque tube, it should be a 6 spline.
  3. hey, thanks.
    didnt realize y'all were on here.
    will the stock 1/2ton rear-end hold up to the 2.3L bangers power as is (stock)?
    thanks
    ncg
  4. HotRodWorks
    HotRodWorks
    Alliance Vendor
    I'm sure it would. I've seen them survive with a lot more torque applied to them than a 2.3L will put out.
  5. rodrelic
    rodrelic
    Yes, hold up OK. As a rule the pickups were 4.11 and the cars 3.78, optional was 4.56 in pickup.
  6. pasadenahotrod
    pasadenahotrod
    from Texas
    Hey man, those early Ford rearends were holding up behind 392 Hemis, Cadillacs, Oldsmobiles, Nailheads, Pontiacs, Chevys, and on and on.
    A 2.3 Ford 4 cylinder? I think so.
  7. A Harley servicar rear would hold up to that motor stock.
    Don't sweat it put it together and if it breaks build it stronger.:D
