Technical 40's Ford Perch Bushings?
Discussion in 'The Hokey Ass Message Board' started by Old35Matt, Apr 26, 2017.
  1. Old35Matt
    Old35Matt
    from Oklahoma
    I have a set of 40's Ford wishbones that I split for my 35 Ford PU.
    There seems to be a sleeve or bushing in the perch, it's worn down and I am wondering if anyone has experienced this and if there is a replacement or aftermarket sleeve or bushing.
    Sorry, no pic, I'm at work.
    Thanks
  2. alchemy
    alchemy
    It's probably the outer shell of the shackle stud. Use a hacksaw to cut the thin shell and you can push it out. If you use original style shackles the new studs will have the insulator and shell on them. If you go new hot rod style they will probably come with urethane bushings.
  3. Old35Matt
    Old35Matt
    from Oklahoma
    I will give this a try.
    The new set up is a 4" axle drop with posies reverse eye spring and chassis eng. shocks.
  4. that picture makes it appear everything is fine.....what exactly is the issue?
  5. Old35Matt
    Old35Matt
    from Oklahoma
    The perch has some play in it. It's not a snug fit, which I would assume it needed to be - but this is my first build, so I'm unsure.
  6. what part are you calling a "perch"? where the axle and wishbone join? i'm confused
  7. Old35Matt
    Old35Matt
    from Oklahoma
    The front of the wishbone where the leaf spring & shock meet the 3 pronged "assembly"
  8. you must be missing the shackle bushings , they should of came with those Chassis Engineering shackles
  9. Old35Matt
    Old35Matt
    from Oklahoma
    There were rubber ones, however they will not fit - so I will attempt to remove the metal sleeve/ bushing that's in there now.
    I will get a pic a post it before I do anything this evening.
  10. Pete and Jakes has those shackle bushings and can have them to you in a couple of days.
    lothianwilly71 likes this.
  11. Old35Matt
    Old35Matt
    from Oklahoma
  12. alchemy
    alchemy
    Any aftermarket shackle is gonna require you to remove all of the original shackle stud and its thin steel housing. All you should have left before you put the new urethane bushing into the hole is the plain forged Ford perch.
  13. Roothawg
    Roothawg
    Matt, I misunderstood your text. I thought you were talking about the pin where the wishbone attached. My bad.
    The bushings can be bought made of oilite material. Screw those poly bushings.
  14. Old35Matt
    Old35Matt
    from Oklahoma
    Sounds good, who's the vendor/ part number?
    Thanks!
  15. Call Pete and Jakes @ 800-334-7240. Tell 'em what you have and they will fix you up. I can't remember the part# but they're inexpensive, $4.80 ea.
  16. Roothawg
    Roothawg
  17. Old35Matt
    Old35Matt
    from Oklahoma
    Looks good, thanks!
    lothiandon1940 likes this.
  18. Old35Matt
    Old35Matt
    from Oklahoma
    Finally got to the perches today.
    I used a jewelers hacksaw to cut reliefs in the bushings, then took a chisel and hammer and folded the top in and then used a brass punch and hammer to knock the old bushing out.
    I replaced it with the rubber ones that came with the kit, but I'm keeping the oilite bushings in mind for down the road.
    Thanks for the help.
  19. Roothawg
    Roothawg
    Now, get back to work slacker!
  20. Old35Matt
    Old35Matt
    from Oklahoma
    I'm trying!
    I put the front end back together yesterday and bolted in the transmission plate.
    The wishbone frame tabs should arrive today so I can get those welded on.
    And I did get the differential mocked up this past week and spot welded in.
