'40 Willys Gasser P/U Frame Pic's/Diagrams
Discussion in 'The Hokey Ass Message Board' started by Candy-Man, Feb 21, 2012.
  1. Candy-Man
    Candy-Man
    I have searched the HAMB, however; I cannot locate any good pic's or diagrams for a '40 Willys Gasser P/U Frame.... Anyone have a few good pic's with some measurements, for a 40 Willys Gasser Frame ?
    Thx...
  2. trashn'l
    trashn'l
    Candy man, I have a '39 Willys pickup frame. There are pictures in my album. I can get you whatever measurements you want. Here are the measurements from a another thread here on the HAMB. Let me know if I can help.
  3. xracer40
    xracer40
    Here's a picture of a rolling chassis you can use with the above diagram.
  4. Candy-Man
    Candy-Man
    Perfect..... That is exactly what I was looking for....
  5. porkshop
    porkshop
    from Clovis Ca
    How about some pics of the body you bought THANKS JOHN
  6. boogeracng
    boogeracng
    from Eureka,MO
    Careful.....the '37-'40 frames are basically the same dimension wise. The '41-'42 frames are the same basic SHAPE/DESIGN, but TOTALLY different as far as dimensions, body mounting points, spring shackle pivot points. The sketch of the '41-'42 is spot on. Never seen one like it for the earlier frames....would be a nice addition to my reference library.
  7. Candy-Man
    Candy-Man
    boogeracng : Sounds good. I understand the 41/42 is 2" longer than the 40 ?
    porkshop : I'll post pic's of 40 P/U sheet metal, after I pick it up early next week...
  8. Weasel
    Weasel
    1941/42 is not only longer wheelbase but also 2" wider from the front of the rear kickup to the end of the rear frame horns. The 1941/42 frame is very different from the 1940 with a completely different
    X member and uses a totally different gas tank as well as a 2" wider rear axle....
  9. Candy-Man
    Candy-Man
    Here are a few pic's of the body when I picked it up....
      56.7 KB
      63.6 KB
      63.2 KB
  10. porkshop
    porkshop
    from Clovis Ca
    Thanks for the pics, Looks like you got a great deal. Wish I hadnt missed it.....JOHN
