Hot Rods 40 Ford driveshaft pin removal
Discussion in 'The Hokey Ass Message Board' started by Jmorton27, Jan 16, 2016.
  1. Jmorton27
    Jmorton27
    Anybody have any tricks on getting these out? ImageUploadedByH.A.M.B.1453003496.998809.jpg
  2. Take a center punch and punch either side of the pin. Then take a drill bit the same size as the pin and drill down just below the surface to remove the head. Take a drift or pin punch and a BFH and smack the pin all the way out. Done.
  3. Bader2
    Bader2
    Use a grade 8 bolt when putting it back together.
  4. Yep, and a stover lock nut or nylon lock nut. I like the stover ones better since gear lube might break down the nylon over time and soften it.
  5. thirtytwo
    thirtytwo
    Bolts like to break for some reason ... You can still buy the soft pins
  6. 42merc
    42merc
    Bolts, especially hard bolts like to break because the the coupling will "work" on the splines .
    Not much, but enough to shear the hard bolts.
    The soft original pins work the best.
  7. Dak Rat
    Dak Rat
    42merc is correct. The pins are very soft and will "give" a little if the splines are worn and move around some--hard bolt will shear.
  8. Bader2
    Bader2
    Well,I guess Vern tardel and I are the only ones who will be breaking grade 8 bolts then! ImageUploadedByH.A.M.B.1453267265.029699.jpg
  9. 39 Ford
    39 Ford
    Used a nail back in the day, never had one fail
