Technical 40 Ford Coupe w/302
Discussion in 'Traditional Hot Rods' started by 1/2done, Jun 6, 2020.
  1. 1/2done
    1/2done
    from Ohio
    Has anyone run a 302 in a 35-40 Ford and used a front sump pan? It looks like it would only need to be set back about 5-6".
  2. sloppy jalopies
    sloppy jalopies
    I see a modern, double hump, new, oil pan for $60 free shipping
  3. 40Standard
    40Standard
    from Indy
    I know that a SBC will drop right in.....
    47ragtop, B Bay Barn and studebaker46 like this.
  4. HotRod33
    HotRod33
    What's wrong with keeping a ford in a ford???
    loudbang and warhorseracing like this.
  5. Small block Chevy drops into mostly everything.
  6. Oh, I see it's ground hog day again.:rolleyes:
    warbird1 and warhorseracing like this.
  7. Fords are longer engines.IF you need to recess the fire wall to make it fit its at the cost of leg room.There are water pump options to shorten them.
    warhorseracing and uncle buck like this.
  8. southcross2631
    southcross2631
    I have a new Ford Motorsports pan and pickup tube you can have for 20 bucks and the freight.
    PM me if interested.
    warhorseracing likes this.
  9. Moriarity
    Moriarity
    SUPER MODERATOR
    331 Cadillac drops right in
    7038266D-EB61-4190-B22E-C253A11E79F7.jpeg 36DC0EBA-0C21-4CC3-9799-C8A53B742DC1.jpeg
    IronFord, F-ONE, chevyfordman and 7 others like this.
  10. 42merc
    42merc
    Only set back 5 or 6 inches ?
    Tape a couple of 2x4's to your pedals & see if your feet will fit between the seat & the pedal.
  11. LOU WELLS
    LOU WELLS
    from IDAHO
    Do Not Let The Pan Rule The Swap...Cut The Pan To Conform With The Cross Member.. 41pu165.jpg
    40FORDPU and 47ragtop like this.
  12. RJP
    RJP
    from PNW
    rpm56 likes this.
  13. Moriarity
    Moriarity
    SUPER MODERATOR
    it doesn't.....
    warbird1 likes this.
  14. 1/2done
    1/2done
    from Ohio
    The block I have is early, no dipstick hole in the block. The early rear sump kits run $250.
    The body is a shell on a cart at the moment, it's getting channeled to the bottom of the frame. If I have to I can move the seat back.
    irishsteve likes this.
  15. southcross2631
    southcross2631
    Not if it has a dipstick hole in the pan like the I have .
  16. F-ONE
    F-ONE
    from Alabama
    Nothing is wrong with keeping a Ford in a Ford especially if you keep the Ford it came with in the Ford. Otherwise it’s a royal pain in the butt.
    No Ford overhead valve V8 Ford engine is easy to put into an early Ford V8 car. Some are downright difficult.
    Been there and I have the T shirt.
    Remember Ford always had a better idea and used them all.
