Clear CO Title in hand Media Blasted- no bondo or surprises! Bare metal "Short" list of Parts: Rebuilt 350/350 with new Edlebrock carb, noisy dear drive, one newly chromed bumper (have both), window moldings, exterior trim, stock radiator, Kwik Wire 22 circuit harness, chrome steering column w/tilt, shift and keyed. Billet dash gauge panel, Autometer gauge set, new glove box, electronic wiper conversion kit, automatic trunk lift kit, running boards (original and media blasted), new running board covers, rusted area in rear tool tray needs repair, firewall needs repair (extra fire wall be included), polished aluminum overflow tanks. Stock frame, Fatman Mustang II front crossmember installed with front shocks and springs, 2.5" exhaust installed with turbo mufflers, Speedway dual feed master cyl., brake lines installed with w/ residual valves, proportioning valve, and brake light switch installed. Speedway front disc brakes, 4.5" bolt pattern, Speedway power rack and pinion, stock a-arms, etc. Chassis engineering rear parallel leaf spring kit installed. Ford 8" rear end w/drum brakes. Chassis engineering trans kit installed. Polished 14x6 and 15x7 Mehelic wheels. New BF Goodrish tires, Weiand intake, edlebrock air cleaner, M/T valve covers, ceramic tight fit headers, rebuilt 350 trans, gas line and gas tank installed. All stock handles. Car has minimal rust with approx. $900 in new pafts from Dennis Carpenter and Bob Drake (rubber window grommets, etc.) Call and ask for Alex at 720-935-9072 email: [email protected]
