Does anybody know if a 1965 ford 4 lug pattern would be the same as a saturn bolt pattern... Sent from my VS990 using The H.A.M.B. mobile app
Google lug patterns. There are dozens of them out there, The Mustang pattern was 4 on 4". It seems the Saturns are the same, but there are lots of different models and years of Saturns. Warren
I tried but kept coming up with 4.5 pattern on the falcon.. Sent from my VS990 using The H.A.M.B. mobile app
Saturn is 4x100mm Or 4x3.937 Ford is 4x4-1/2 Or 4x114.3 mm No they won't bolt up and I bet the offset is different too. Check with "rotten Leonard" and see if he has a redrill jig
OEM and aftermarket 4-Lug wheels for 60's Fords are not exactly hard to find. Why on earth are you looking at Saturn wheels?
funny....saw a set of Weld Wheels....skinny's on front.....big's out back....on a four lug Mustang...just yesterday....lot's of guys rand those 20 yrs ago....
Fox-body Mustangs are not the same pattern as early Falcons and Mustangs. In 1975, the Ford 4-lug pattern switched from 4-on-4-1/2" to 4-on-1-1/4".
Just a note . I tried to put 14 in. 4 lug Ford wheels on a 62 nova 4 lug to replace the 13 in. tires. I had to machine the center hole out to clear the Chevy hub,after that it bolted right on.
Mr. Gimpy is right. Ran across this recently trying to find wheels to fit my buddies Anglia. Early Ford stuff 4.5. Later and Fox body 4.25. Four lug Weld wheels (ones with the round holes) seem to have both patterns. My friend does have some adapters 4-4.5 to 5-4.5 that he might sell. Can ask him. P.M. me if you want to know. Gene.
