4 door to a 2 door.
Discussion in 'The Hokey Ass Message Board' started by John O, Apr 3, 2008.
  1. John O
    John O
    from Central NJ
    Gent,
    I have asked some of the local NJ experts on this subject. Competent men I assure you. However, I'm looking for as much sage info as I can gather. 1954 Merc Monterey 4 door to a 2 door. Have you done this...whats the best way to accomplish the task.
    As always..thanks for the sage advise. Detractors kindly fo.
    Johnny O
  2. ol'skool29
    ol'skool29
    they did a 2 part article in rod and kulture mag recently to a ford of the same body style, they took 2 door doors, and welded the rear doors far enough back to fit the longer doors.
    btw, 4 doors are better!
  3. FiddyFour
    FiddyFour
    i've seen this done both ways.. slice the door middle section and lengthen to meet the new longer opening after the b post is moved, and also seen it done using donor two-door doors as well. both are a TON of work, but for a monterey 54? might be worth the effort
  4. Psychobilly351w
    Psychobilly351w
    from 732- NJ
    Could take the easy way out and just weld up the back doors leaving the fronts stock..
    Joe.
  5. DrJ
    DrJ
    You could enter it in a destruction derby too. That would be the same waste of a good car. :rolleyes:
    Ain't no "easy way".
    If you're going to do it, do it right.
    Lengthen the front doors or get some two door doors as said above.
    If you find some two door doors, bag the split back front seat while you're at it, and the 1/4 windows and crank stuff.
  6. Shoprag
    Shoprag
    I'm with DrJ. 2 door, doors would be way easier then lengthening the 4 door, doors but if your strapped for cash then lengthen the doors.
  7. Swifster
    Swifster
    The easy way is to start with a 2-door. If you wanted a 2-door...:rolleyes:
  8. Oldsmobucket
    Oldsmobucket
    you could for go all the hard work and leave it a four door . just my .02
  9. FiddyFour
    FiddyFour
    how did i know someone would suggest this shit?
  10. Squablow
    Squablow
    What would be really cool is if you swapped the roof and doors from a 52-54 Ford business coupe onto the Merc and make a phantom Mercury business coupe. (see the included picture below. Has a much shorter roofline than the 2 door sedan but same body and wheelbase. Trunklid is the same too) There is an article floating around showing a '57 Chevy getting converted that used the whole roof, turned out great.
    My Plymouth didn't require a different roof, just 2 door sedan donor doors, but plans for my '57 Chevy are to use a whole roof from a '56 donor car I have in the back yard.
    Here's a rundown of my '60 Plymouth if you haven't read it yet. It's pretty straightforward.
    http://www.jalopyjournal.com/forum/showthread.php?t=78120
    There are a few other conversion techs on the HAMB, check them out.
  11. Pir8Darryl
    Pir8Darryl
    Why would you want to do that?
    Look here:
  12. Pir8Darryl
    Pir8Darryl
    And as to lenghtening the front door and welding up the rear, it has been done before...
  13. Squablow
    Squablow
    I want all the pieces of the car to be interchangeable with stock stuff. That means fully functional quarter windows with regulators, and unmodified doors.
    Not saying that the doors-only conversion isn't impressive, but I've got the pieces so I'm going to do it all the way. The car is eventually going to be restored stock as a Belair clone so I want all the stock shit to fit together.
  14. Squablow
    Squablow
  15. Pir8Darryl
    Pir8Darryl
    Wow! Lot of work. Even the guy who did it admitted it was. I especialy like this quote:
    Seriously tho, I'm QUITE sure the roof's are the exact same sheetmetal. All you really need is the doors, door jamb "B-pillar", and outer 1/4's along with the inner 1/4 sections from the passenger compartment. Oh, and also, the frame from around the back side glass.... No need to totally re-invent the wheel.
    Converting a Merc from a sedan to a short roof business coupe might actually require that much work tho.
    Either way, too much work for my tastes, no matter how cool the outcome.
  16. I would think that it would be sensable to sell the car and use the money to find a 2 door that you like.
  17. straykatkustoms
    straykatkustoms
    We're almost done with a 4dr to 2dr '50 Merc conversion. I had the opportunity to buy a set of two doors but I'm working on a thin budget and didn't have the extra $$$ to buy them. Ralph Schindel extended the doors from a parts car that I had in my back yard. Lot of work involved but it worked out just fine. Also Traditional Rod and Kulture magazine had one of the koolest how to articles that I've seen in a while. Two issues had a how to do it to a '52 or '53 Ford. Be sure to check it out!!
    For a guy that is limited $$$ and has some "How to" talent, this is the way to go.
    Happy Trails,
    Mick
      51.2 KB
      64.1 KB
      64.6 KB
      57.6 KB
  18. John O
    John O
    from Central NJ
    Thanks gents...Squa, good tech article. The car is super solid (not an original northeaster) and I was just toying with the idea of a conversion. It's still a great car as a four door.
  19. Shoprag
    Shoprag
    I've posted these before, Kelley's 52 buick he converted with 2 door, doors.
  20. UnIOnViLLEHauNT
    UnIOnViLLEHauNT
    Just my opinion, but a 2 dr sedan 54 Merc is only marginally more attractive than a 4 dr. 2 dr hardtop is where its at, but then you are talking different roof, glass, nightmare for sure.
  21. Clark Kustoms
    Clark Kustoms
    from las vegas
  22. Eddiesixem
    Eddiesixem
    get the doors and do it!!!! i did mine.....and hardtopped it too.....
  23. Shoprag
    Shoprag
    eddiesixem, where u located lake isabella area or tehachipi area??
  24. thewishartkid
    thewishartkid
    I think it would just be a cool thing to do "JUST FOR THE HELL OF IT!".
  25. Clark Kustoms
    Clark Kustoms
    from las vegas
    I should have hardtopped my chevy . That looks good.
  26. 57JoeFoMoPar
    57JoeFoMoPar
    I say go for it. However, I say that giving you the benefit of the doubt that you are at least a semi-experienced metal worker with enough skill to put the car back together again. This is the equivalent of heart surgery for a car, so if you're unsure of your capablities, I'd recommend not taking the project on without the assistance of someone more experienced. I don't say that to be a douche, but this is a serious project, and you don't start swimming in the deep end.
    The best way I can think of would be to find complete 2 door doors, then cut the B pillar out at the rocker, move the entire assembly, shorten the rear door, and weld it in to essentially become the quarter.
    As Chris mentioned, the 2 door sedan 54 Mercs are still pretty homely, so a chop would be almost essential to justify all the work. If you do it, avoid the chop that most of these cars get, where the whole roof comes straight down and flattens the car rather than making it look more sleek. This is likely due to people trying to keep the door frame perpendicular to the post. Throw the rules out the window and do what it takes to get the roof line right, even if it means slanted b pillars or curved door frame. A shoebox rear window might be a good call.
    Regardless, if your rich on talent and broke on cash, this is a great way to achieve kustom glory on the cheap
  27. roadkillontheweb
    roadkillontheweb
    My Desoto started life as a 4-door sedan.
    Then the factory turned it into a coupe UTE. If you take off the inside bed panels you can see where the rear door skins have been leaded in place. This is a little different path than everyone else has been going but I think it looks good with the original doors.
