4-71 Dual Quads
Discussion in 'The Hokey Ass Message Board' started by shane85, May 26, 2013.
  1. shane85
    shane85
    Is anyone running Edelbrock 1405 carburetors on a dual quad set-up on a 4-71 for small block Chevrolet?
  2. PackardV8
    PackardV8
    No, but I'm sure it's been done, even if it's wrong. We've seen photos of 4-4bbls on blowers. For some too much is not enough.
    IIRC, the inlet of the 4-71 is so small, 2x4 would not dump straight in and would require a tall carb mount plate longer than the blower case. That's probably why I can't remember ever seeing an aftermarket 2x4 setup.
    Decide if you want max power or outrageous appearance. If just max power with driveability, then a single would be the way to go.
    jack vines
  3. madmak95
    madmak95
    I dont know what carbs ill run on my 331 hemi but I lucked out and found this 4-71 2-4 adapter at a swapmeet.
    Sent from my DROID device using the TJJ mobile app
  4. shane85
    shane85
    Well I know it's been done. Weiand made a 4-71 adapter for 2x4 barrel carbs. Just seems like an awful lot of carb .It's what i have on my 4-71.
  5. I had two (i thunk 650s) on a 283 and it ran awesome. Got 20 mpg on highway. Carl5coupe has the engine and blower set up now. I ran them progressive and linked one to one for max power. Awesome.
  6. amadeus
    amadeus
    Not sure if this will apply to you with the smaller 4-71 but you should research "boost referencing -carburetor" (which will apply to a carb with power valves) if performance is your goal ; but being that you are thinking of running the edelbrocks I'm guessing that on a low boost,street driven car this will not apply?
    JW
  7. My AFBs are also not boost referenced but set up for proper enrichment in the secondaries. Not a bad idea in theory but not absolutely necessary either. Lots of opinions out there. I've got plenty of miles and great performance without boost referencing.
  8. Mnhotrodbuilder
    Mnhotrodbuilder
    from Afton, MN
    Yeap they make/made them, I picked up one a while ago. I still have to find carbs for it though. What type of carbs are you running?
  9. choppedtudor
    choppedtudor
    I'm gonna run 2x2 on mine:
  10. Jmountainjr
    Jmountainjr
    Great advice if running a Holley carb with vac operated power valves. But the AFB / Edelbrock use metering rods for the transition enrichment, so there is no need to reference any vac signal.
  11. Lockjaw
    Lockjaw
    i'm running 2-500cfm afb carbs. a bit rich on the lower end but i'm happy with the way it runs
  12. I ran these two stock 425 AFB's for 5 years on the street. They were just as they had come off a '56 Corvette, on a Weiand adapter, and they ran great. The engine was 292 ci, 8:1 with a 315 Duntov cam. As good as it got in '63.
    silent rick likes this.
  13. shane85
    shane85
    on stock jet?
  14. nexxussian
    nexxussian
    I remeber seeing a fellah from Montana that had two Edelbrock carbs on a 471 on a SBC, in an Anglia.
    Saw him at the GG Spokane event a few years ago (one of the places we go after Speed Week) he had driven the car there from Montana (or so he claimed, looked like a reasonable calim at the time).
    His linkage was set up direct (1:1) I don't recall what size carbs. :(
  15. aus996
    aus996
    from australia
    Just looking at two 625 afb,s using one of the weiand duel quad adapters myself, overkill maybe but it sure looks good
  16. shane85
    shane85
    cool i have 2 600 cfm on a weiand its wayyyy rich on stock parts
  17. abone1930
    abone1930
    I picked me up a complete 471 setup for a SBC setup , one had dual AFB's on it, anybody know a vintage looking scoop that would go with this setup . Going 60,s style with my willy gasser project. The carb adapter setup is also weiand
  18. mechanic58
    mechanic58
  19. Thanks man. It was a 3.90 gear and the tires were 31.5" dia bias
  20. shane85
    shane85
    what ignition is in your car?
  21. MSD Btm
  22. 41rodderz
    41rodderz
    from Oregon
