4.30 gears for 57-64 Olds dropout rearend?
Discussion in 'The Hokey Ass Message Board' started by old jetstar, Apr 1, 2013.
  1. old jetstar
    old jetstar
    from oswego,KS
    Does anyone know if they were ever made?I think that's really the gear I need......
  2. I believe the Pontiac hams interchanged with the Olds. Pontiac did have more ratios available, their 4.33 should be the one, IIRC. You can always pick up an aftermarket R & P.
    Bob
  3. Mike VV
    Mike VV
    from SoCal
    Yes sir, the 4.30 ratio was made. Had a set in my ol Anglia for a while.
    Mike
  4. blubiu65
    blubiu65
    from Colorado
    Yes they were
  5. an1951
    an1951
    These people can help you out on tech, gears and parts for the 57-64 Pontiac/ Olds rear end stuff.
    link=http://www.fabcraftmetalworks.com/
  6. Back many years ago I had a 1950 Oldsmobile model 76 (6 cylinder auto trans)that had a 4.30:1 rear axle. Someone told me once they were known as,"mountain gears" but couldn't explain why. This particular car came from Colorado so it may have been an optional ratio. When I installed a rather large later model Olds(475 cu.in.) I wound up welding the spiders because the single track would spin all day and a posi unit wasn't available.
    I have a 4.56:1 posi unit in my 57 Safari but those are Richmond gears.I'm sure you can find a 4.30 gear set for the 57 rear but it will require(IIRC)a spacer for the ring gear to properly set it up.
  7. bobwop
    bobwop
    from Arley, AL
    contact Brad at Fabcraft...as mentioned.
    I ran a 4.30 in the Willys. Yes, they were made
