Hot Rods 3x2 setup on a 671 Blower
Discussion in 'The Hokey Ass Message Board' started by Bonehead II, Mar 31, 2020.
  1. Bonehead II
    Bonehead II
    Hey Guys..I have a 3x2 setup with small base Rochester carbs, that I want to put on a 671 Detroit blower, I was told by a guy that I would starve the front and rear cylinders of fuel. also I would like to use a progressive linkage. This is only for the street use.
    Please let my know what you think.
    Thanks
  2. Jmountainjr
    Jmountainjr
    Before diving in, I would think through some technical issues:
    The vaccum operated power piston will see constant vacuum from being on top of the blower. There are ways to modify a carb to see manifold vacuum. It's called boost referencing. Not sure how to do it on your carb.
    Do some research on fuel total requirements. If your tri power set doesn't have idle circuits in the end carbs you might have some tuning issues.
    The tri power on a blower has been around for a long time, but usually with different carb choices. Hope you get it all worked out and let us know.
    Bandit Billy likes this.
  3. ^What is said above^. Also, progressive linkage, no. Diving around on one two barrel is not going to feed a 671 equipped engine. Research blower threads and read lots of info.
    Desoto291Hemi likes this.
  4. squirrel
    I put over 100k on a progressive linkage dual quad holley setup on a blower....it works fine....you'd be amazed how well it blends. And I doubt it's going to need boost reference, because it won't make much boost without letting in much air, because....
    The big problem I see is that three deuces is about half the CFM you need on a 6-71. Maybe if you could squeeze 6 or 8 of them on there, you might have something.
  5. DOCTOR SATAN
    DOCTOR SATAN
    from okc
    Now we're talkin'.....
  6. Mat Thrasher
    Mat Thrasher
    Here's my 6x2 set up that I run a progressive linkage on. The front two driver's side carbs are the primary carbs. It's an 8-71 on a 582 BBC, the carbs are large base Rochester 2g's.
    It's runs great on the street and the track. I never had any issues with any cylinders running lean.
  7. Bonehead II
    Bonehead II
    OK..then what size of Holley carb's should I be looking for, remember street only.
    Thanks
  8. DDDenny
    Are we supposed to guess what engine you plan on putting this setup on?
    Size matters!
    Engine size that is.
  9. squirrel
    500 to 750 depending on the size of the engine.
    VANDENPLAS likes this.
  10. Seriously??? I know it won't be long before Google can read your thoughts and predict the futures, but we aren't there yet.
    Tell us about the engine combo. Big difference in carb requirements between bolting that 6-71 to the side of a 300 I6 or on top of a 460 punched and stroked to 600 ci.
    Bandit Billy and mad mikey like this.
  11. Jack E/NJ
    Jack E/NJ
    from NJ
    >>>I have a 3x2 setup with small base Rochester carbs, that I want to put on a 671 Detroit blower>>>
    More likely a 350. 8^) Jack E/NJ
  12. Jalopy Joker
    Jalopy Joker
    why try to run 3x2 set with blower?
  13. Bonehead II
    Bonehead II
    Sorry guys...I feel like a dum ass....its a 350 with a 383 forged crank, rods, & pistons...30 over...Edelbrock 70cc chamber heads,
    671 Detroit blower converted and rebuilt for gas.
    Desoto291Hemi and Deuces like this.
  14. Bonehead II
    Bonehead II
    I like the old school look
  15. squirrel
    When was three rochester 2bbls on top of a 6-71 ever a look?
    Just curious.
  16. Jalopy Joker
    Jalopy Joker
    so, do you have any pictures of "old school" 3x2 / 671 to share here?
    Gasser 57 and mad mikey like this.
  17. Bonehead II
    Bonehead II
    sorry I don't I just like the look of 3x2 set up.
    Deuces likes this.
  18. Boneyard51
    Boneyard51
    I don’t know anything about blowers, but I like 3x2s also! Sometimes it’s about what you want.....not necessarily what you need!
    Desoto291Hemi, VANDENPLAS and Deuces like this.
  19. Jack E/NJ
    Jack E/NJ
    from NJ
  20. Could always go with 3 AFB's like this guy. I talked to him at a show several years ago and he drives it all over the place.
    mad mikey, Deuces and Jalopy Joker like this.
  21. Blues4U
    Blues4U
    from So Cal
  22. Blues4U
    Blues4U
    from So Cal
    There's this one in the Induction thread:
  23. Blues4U
    Blues4U
    from So Cal
  24. Bonehead II
    Bonehead II
  25. Bonehead II
    Bonehead II
    If there is anyone out there running 3x2 carbs on a 671 street blower, would you please tell me what your running for carbs and what kind of CFM you have.....Thanks
  26. Jack E/NJ
    Jack E/NJ
    from NJ
    Just use the ones you already got first. Jack E/NJ
  27. flamedabone
    flamedabone
    For comparison, my 389 inch Pontiac with a 6-71 has two 750 cfm carbs. I started with two 600s, but the dyno proved them too small. To make boost, blowers need to draw free air through the suction side and three small cfm carbs may be too much of a restriction. They may also not be able to supply enough fuel, but only an air/fuel sensor can tell you for sure.
    What are the cfm ratings of the carbs?
    -Abone.
    Jalopy Joker likes this.
  28. flamedabone
    flamedabone
    I did a quick HAMB search and it appears Holley 94s are about 185 cfm. If so, three of them might be OK on an unblown small block, but adding a supercharger will be dicey. A huge key to a blown engines lifespan is fuel delivery.
    Another option is to hang six of those suckers on there like Thrashers ride. Plenty of cfm and it looks kick ass.
    -Abone.
    Desoto291Hemi and VANDENPLAS like this.
  29. sdluck
    sdluck
    My buddies 32 ford glass car we built has a 406 chevie with a tk 500 trans and 4:11 gears has twin 750 holley blower carbs on a 8:71 runs excellent ,it is a street car,good gas mileage.I drove it from san jose to Pleasanton a few times
  30. Jack E/NJ
    Jack E/NJ
    from NJ
    2Gs ranged from about 250 to 450. Jack E/NJ
