392 hemi ????
Discussion in 'The Hokey Ass Message Board' started by TomWar, Nov 29, 2010.
  1. TomWar
    TomWar
    It's been a long time, but do you use the Spark plug washers and the tubes? Or just screw the plugs in the tubes without the washers?
  2. Gotgas
    Gotgas
    from DFW USA
    No washers. The conical shape of the plug will seal the tube.
  3. It is six of one, and half a dozen of the other. Neither way will make any difference...
  4. 150J/F
    150J/F
    No Washers.
  5. thumpr
    thumpr
    If your running the 392 plug wires i'd use washers. if you have the adapters to run later model plug wires with the boot over the tube i'm not sure. I do have a perfect set of plug covers,valley cover and timing cover (minus fuel pump drive) i would sell
  6. George
    George
    The shop manuals say no washers, Chr should know the answer!
  7. The original poster was referring to the gasket washers at the spark plug threads, not the washers that clamp the grommet a the top of the spark plug tubes.
