My friend has a 392 with a stock 2X4 manifold. Should he have progressive linkage? My Wiend manifold is open so a progressive works. I just wonder if the stock manifold is open like that?
The 1955 300 intake picture above would benefit from fixed linkage due to the smaller seperated plenum, but the later manifolds have a very large open plenum and progressive may work better if the carbs are big. Run the rear carb as primary. .
If you use edelbrock carbs don't use progresive linkage. I have tryd that. I drived the car with a lamba meter and that said thats were not good It gave mutch better result with linkage that open both on same time, with out changing annything else .
