i have a friend who has a 39 transmission the stick moves in all positions, but seems too loose and easy, also jumps out of gear on occasion. any suggestions? Thanks
Sounds like it's worn out, time for a rebuild. Sloppy shift lever indicates that the top end is loose, pops out of gear is also affected by shifting mechanism, syncro, thrust washers and bearings. Not a difficult trans to repair and should be done before you explode it.
