39 chev susp. ?
Discussion in 'The Hokey Ass Message Board' started by Fasterthanu, Jun 24, 2008.
  1. Fasterthanu
    Fasterthanu
    Where would I find a leaf spring front axle for a 39 chevy master? Any direction would be great.
  2. Torkwrench
    Torkwrench
    Look for a front axel out of a 55-59 Chevy/GMC 1/2 ton pickup. A friend of mine (who has one under a 33 Chevy) suggested one for my 34 Master. He said it is the same width as a 34,(he had to narrow it for his 33), so it probably will work for a 39 too. To have 5 lug hubs, look for 51-54? Chevy pass. car front hubs. I'm not sure if the springs will work though.
  3. Armstrong
    Armstrong
    I think that in '39 the Master had independent frnt suspesion,but the Standard models had the beam axel. The front axel from a '37 or '38 Standard should be the same. You'll also need the brackets to attach the beam to the frame. The brackets are riveted to the frames on the Standards and are removed by drilling the rivets out.
