Projects 38 ford coupe from downunder downunderIve done
Discussion in 'The Hokey Ass Message Board' started by mercurymitch, Jun 11, 2011.
  1. mercurymitch
    mercurymitch
    from Australia
    Making door the same way i made the running boards,and the tools needed to do the job
  2. mercurymitch
    mercurymitch
    from Australia
  3. farmer12
    farmer12
    Amazing work, love the fabrication skills. Keep it up!
  4. richie rebel
    richie rebel
    you sir,have a great deal of talent,i will be watching this build very close
  5. mercurymitch
    mercurymitch
    from Australia
    As i said the bottom of the door hit the front fender so i had to enlarge the radius of the doorway
  6. mercurymitch
    mercurymitch
    from Australia
    Another pic of the door edge
  7. mercurymitch
    mercurymitch
    from Australia
    Hi all,got a bit ahead of my self .I made hinge posts in true hot rod style recycled a belt cover from a paint stirer.I bought some industrial hinges and welded a piece on at right angle
  8. mercurymitch
    mercurymitch
    from Australia
  9. mercurymitch
    mercurymitch
    from Australia
    The attaching holes for the hinges were made larger for door adjustment
  10. mercurymitch
    mercurymitch
    from Australia
    useing the shrinker/stretcher i made the doors,this took quite a while
  11. mercurymitch
    mercurymitch
    from Australia
    I used a sliding nut plate so i can adjust the doors up or down or in and out
  12. mercurymitch
    mercurymitch
    from Australia
  13. Wardog
    Wardog
    Wow! the level of craftmanship in this is amazing! Well done.
    P.S i'd kill for you're english wheel.
  14. mercurymitch
    mercurymitch
    from Australia
    Door top in place
  15. mercurymitch
    mercurymitch
    from Australia
    Then made and welded in the window runner to the door top
  16. donut29
    donut29
    from canton MI
    WOW!!!! Good work
  17. heyitsnate
    heyitsnate
    from tacoma,wa
    Super crazy build!
  18. mercurymitch
    mercurymitch
    from Australia
    Hi all,when i started this build it was just a test to see if i could do it,now i have got this far its time to have a go at the chassis.Having never built a chassis it may be a steep learning curve,found a couple of pics in magazines and away we go
  19. mercurymitch
    mercurymitch
    from Australia
    Lifted the body off,now i have enough body to lift off and split the chassis apart which leaves me with this.I also borrowed another chassis to sit the body on while i built mine
  20. neilswheels
    neilswheels
    from England
    Great work, very interested in the running board fab. Did you just hammer the outer edge over the wooden buck? And what kid of wood did you use, a hard wood or something easy to shape like Pine? Oh, subscribed.
  21. mercurymitch
    mercurymitch
    from Australia
    Hi Neilswheels,as i live inTasmania i used Tas oak[just joking] its a hard wood,just hammered the edge over buck with soft hammer
  22. mercurymitch
    mercurymitch
    from Australia
    Bought a steel frame at auction so i used that to set chassis up on .Found an article in a mag that had some good pics
  23. mercurymitch
    mercurymitch
    from Australia
    Had to pack it up to get the twist out.To the right u can see the rails sand blasted and primed
  24. mercurymitch
    mercurymitch
    from Australia
    Welded on some uprights in the middle of the chassis at the correct width using a centre line and some blocks under to support the rail.These 4 blocks were put on level
  25. mercurymitch
    mercurymitch
    from Australia
    Welded lots of blocks on inside of chassis to drill and tap for inner guards and running boards also to bolt body down
  26. mercurymitch
    mercurymitch
    from Australia
    used the trammel rod to check for square
  27. mercurymitch
    mercurymitch
    from Australia
    Then gave the rear a bit of a kick up just in case i bag it
  28. studebaker46
    studebaker46
    man like everyone else on here i am amazed at the craftmanship on this build with that being said please tell me you were yanking our chain about bagging it tom
  29. Rpmrex
    Rpmrex
    from Indiana
    These are the best threads on the HAMB!
    I can't get enough.
  30. Mart
    Mart
    Great work going on here.
    Subscribed.
    Mart.
