yes with 39 deluxe lights. I am finding impossible to find 38/9 1. running boards 2. inner fenders 3. fenders 4. headlights 5. 39 grille so what is my new shopping list 1. 39 feluxe 40 standard grille front fenders - are they all the same pickup car - I dont think so 40 pickup hood, is different from car. are the inner fender panels the same. what other pieces do I need - the bits you don't see. is this the inner fender brace, the centre bolts to the cvross member are tyhey all the same - i.e. do some 40 fords have a different front crossmember? where do these bits go? Technical - Another 40/41 Ford Truck Question - front fender bracket difference? | The H.A.M.B. (jalopyjournal.com) ahh look on the hamb........ are car and truck 40 ford running boards the same?
front fenders - are they all the same pickup car - I dont think so There is a slight difference where the fender touches the cab of either( pickup is flat, car is curved. Otherwise the fenders are identical and can be swapped if this one spot is tweeked. 40 pickup hood, is different from car. very different, no direct swap are the inner fender panels the same. yes what other pieces do I need - the bits you don't see. various splash panels, your best bet is to get a shop assembly manual
