'37 ford pick up vega box mount question
Discussion in 'The Hokey Ass Message Board' started by scottsrods, Jun 7, 2013.
  1. scottsrods
    scottsrods
    Is the mount supposed to sit a little off the frame rail? Speedway said i use the top existing holes. Just want to make sure.
    Thanks,
    scott
  2. Dreddybear
    Dreddybear
    Are we looking up from the bottom of the frame?
  3. Dreddybear
    Dreddybear
    If we're looking down at the top of the frame then I think it's upside down.
  4. scottsrods
    scottsrods
    Sorry, yes the frame is upside down
  5. Dreddybear
    Dreddybear
    Well then you're good!
    If you're in the fabrication stage you have the luxury of leaving it loose til you get everything hung on the car and your column in, body on, headers, etc. Then you can move it forward or back and tilt it exactly where needed.
  6. scottsrods
    scottsrods
    Thank you. You are very wise indeed
  7. Dreddybear
    Dreddybear
    The problem with having so many people on the hamb now is I can't tell if that's sarcasm or not! :)
  8. scottsrods
    scottsrods
    Actually, it's sincere. I'm trying to balance hurry up and get it done, and not screw it up!
  9. Dreddybear
    Dreddybear
    I hear ya. Taking your time in this stage makes for a nice, tight driving little car that runs like clockwork. When setting up steering box, get your motor in, headers on, etc.. before you weld it in or do any permanent stuff. All these companies say stuff fits but they don't take some of the custom touches you might be doing to your car into account. A big thing is to make sure the pitman can articulate all the way and that the tie rod clears the oil pan.
  10. scottsrods
    scottsrods
  11. olscrounger
    olscrounger
    what they said--looks right but get engine in with exhaust manifolds or headers on then make adjustments as necessary--have had to move some back 3/4 "
  12. need louvers ?
    need louvers ?
    Damned well said Dreddybear!
