Technical 37-39 windsheild frame screw thread size and screw style
Discussion in 'The Hokey Ass Message Board' started by nobby, Aug 7, 2021.
  1. nobby
    nobby
    Hello please help
    what is the thread on a 37/9 winsheild frame where the hinge attatches to the actual frame
    is it a countersunk screw
    is it a domed head screw
    what is its length under the head - max
    anyone have a pic of what they look like?
    thank you
    please confirm for me that that a hinge from a 37 pickup fits a 38
  2. nobby
    nobby
  3. Deuce Lover
    Deuce Lover
  4. Deuce Lover
    Deuce Lover
    Countersunk slotted oval head. 10X32X5/16 If I remember correctly.
  5. nobby
    nobby
  6. goldmountain
    goldmountain
    If it is just 10-32 screws, you should be able to get them from the hardware store. I get mine from the Home Depot but there must be something in England.
  7. clem
    clem
    often difficult to find those imperial ones in the metric countries, - I’ve had difficulty with finding that size.
    Have to go to a specialist bolt supplier.
  8. Sort of related, and going from memory, the hinge mounting screws are 12 x 24 tpi. Which is not a very common size used much now. That would be tougher to find outside of USA.
  9. nobby
    nobby
    I am confused
    the hinge is in two parts
    the hinge plate bolts to the body - waht size
    the moving hinge bolts to the plate - what size
    the moving hinge bolts to the frame - needs to be countersunk - what size
    thanks
  10. Deuce Lover
    Deuce Lover
  11. Avoid confusion, post a picture.
