364 nailhead help
Discussion in 'The Hokey Ass Message Board' started by dirtball666, May 22, 2011.
  1. dirtball666
    dirtball666
    my 364 is not firing in cylinders 2 and 4. i'm sort of at a loss. compression is good, i put in new wires, plugs and rotor. plenty of spark coming out of the wires, the plugs are firing and gapped right. when run, if you pull the wires for 2 and 4 there is no difference. the carb has been rebuilt. the valves do not seem to stick or be bent. the passenger bank is firing clean, but on the driver side the exhaust smells a lot like gas. i'm sort of at a loss. any help?
  2. Make sure that your spark plug is getting a good ground? Try switching the plugs around to different cylinders to make sure that it is not a bad plig on the offending cylinders?
    There is probably a real cure for your problem but that is a start.
  3. 48 Chubby
    48 Chubby
    A compression guage will tell you if the head gasket is blown between the two cylinders. I suspect that it is.
  4. he said that compression is good.
  5. d2_willys
    d2_willys
    from Kansas
    I don't see distributor cap on your list of replaced parts. Might have a crack or a carbon trace causing some weird behavior.
