damn this thing is stuck how the F do I un sieze a torque tube this is in my 32 project not the truck
disconect from the transmission, pull the speedo gear slide the tube forward drill the peened pin head on the splined driveshaft drive end drive the pin out and slide the driveshaft off the pinion
the tube wont pull forward seems to be locked around the drive shaft speedo gear is out whole assembly will spin(tube)and car will roll when i remove all the bolts on the banjoand disconnect the radius rods from the tube
bib overalls you saved me man pulled snap ring chiseled off speedo gear torque tubed pulled forward exposing the problem seized front roller bearing the car rolls man thanks
