Hot Rods '36, going against my ways
Discussion in 'The Hokey Ass Message Board' started by 36 Vick, Nov 12, 2014.
  1. 36 Vick
    36 Vick
    from Kerman, Ca
    Few updates,,,,
    I've been studying that clean looking front end. Think I got it.
    Not sure the pushrod will come off the perch, I may set up a bracket on the top of the wishbone
    Nonetheless, I'm going with an inboard coi lover set up. Found some larger, original ford light ( as oppose to the China imported Dietz replica I already bought) and mounted it from a pitman arm I found that had a bend in it. Now to duplicate another one ImageUploadedByH.A.M.B.1446604689.030085.jpg ImageUploadedByH.A.M.B.1446604718.511074.jpg ImageUploadedByH.A.M.B.1446604748.942948.jpg ImageUploadedByH.A.M.B.1446604760.549754.jpg
    kidcampbell71 and kiwijeff like this.
  2. Glad to see someone is getting some stuff done!
  3. 36 Vick
    36 Vick
    from Kerman, Ca
    Hardly...... Mock up feels like 1 step forward and 5 steps back
  4. 36 Vick
    36 Vick
    from Kerman, Ca
    Sometimes it seems like it would be so much easier to just be a Street Rodder
    brEad and bengeltiger like this.
  5. 36 Vick
    36 Vick
    from Kerman, Ca
    Like I told you Lowcoe, 5 steps back!!!
    Now with the lower stance, I'm redoing the slot in the frame for the Pitman arm, so my drag link is level and I can reset my wishbone mount
  6. 36 Vick
    36 Vick
    from Kerman, Ca
  7. 36 Vick
    36 Vick
    from Kerman, Ca
    Looking for some feedback....
    Here is a look at the rear end suspension I put together. With sway bar and panhard bar.
    Things are tacked in. My key concern is that functionally it will all work. Cosmetically I will clean it up a bit
    Everything is in square and true. Based on all I've studied, it should work
    But would just appreciate constructive criticism
    Good day ImageUploadedByH.A.M.B.1449500771.022795.jpg ImageUploadedByH.A.M.B.1449500783.994215.jpg ImageUploadedByH.A.M.B.1449500803.987471.jpg ImageUploadedByH.A.M.B.1449500819.495132.jpg
  8. Looks like it should work to me...
  9. King ford
    King ford
    from 08302
    If you run a rear antiroll bar ( sway bar to some) you need to run one of equal or greater rate on the front to keep the rear of the car from trying to pass the nose!..great build, outstanding fab skill...thanks for posting!
  10. skipstitch
    skipstitch
    Too few people take time to step back and look at proportions....
    This is perfect! Wow
  11. 36 Vick
    36 Vick
    from Kerman, Ca
    Mr King, Thank you for the input and please excuse my ignorance. Can you explain, why the effect of a rear sway bar and no front sway bar will affect the car like you say? I don't understand the "rear...trying to pass the nose"
    Thanks again
  12. 36 Vick
    36 Vick
    from Kerman, Ca
    Ok, time for things to get serious.... ImageUploadedByH.A.M.B.1451366726.181404.jpg ImageUploadedByH.A.M.B.1451366753.625743.jpg
  13. King ford
    King ford
    from 08302
    Really nice workmanship and vision 36 Vick! ...on the antirollbar "sway bar" issue the end of the car with more roll resistance will break loose and slide laterally first...look at it like this,when the body attempts to roll the antirollbar attempts to push down on the outside tire and pick up on the inside tire when the end with less roll resistance is less likely to attempt to lift the inside tire therefore in an aggressive cornering situation with only a rear antirollbar the front tires will adhere better than the rear tires causing the car to "spin out " ( the rear passes the nose) ..that is why most America cars have a stronger front antirollbar than the rear...if you had a antirollbar on each end of close to equal rate both ends control body roll and " balance front to rear is achieved
  14. exterminator
    exterminator
    Looks like a lot of work ,but Wow-that car looks MEAN!!!
  15. 36 Vick
    36 Vick
    from Kerman, Ca
    Anyone ever stop and say to themselves, "Self, what exactly did you get yourself into?"
    Well, I am. A blessing and a curse have occurred at the same time for me. My project was moving along and I had called an old acquaintance from some years back for simple advice now and then. Now this acquaintance happen to build the AMBR 2004 winner and has built many other fabulous projects over the last 40 years.
    Long story short, he is living at my place now and teaching me so many ways to further what little skills I have. This man, Mr Larry Ruth is helping me to define and build the car I have been envisioning. NO, he is not a hired hand to build my car. I can't afford that, nor is it my nature to have someone build a car for me. The true nature is that he is showing me 40 years of experience. Teaching me proper ways to weld, work metal and tackle a project, so I can build my car to the best of my ability
    He has even shown me ways of grinding that make the project that much better
    The BLESSING is the kind, teaching nature of Larry, the CURSE, my project went back to ground zero. ( as in, rebuild it so the car is not within a degree of level, but .00 of level, front to back
    So here we go...
    PS my wonderful wife surprised me with a Lincoln TIG for Christmas
    And the English wheel is under construction
    God is good all the time and all the time God is good ImageUploadedByH.A.M.B.1453693281.104996.jpg ImageUploadedByH.A.M.B.1453693308.233110.jpg ImageUploadedByH.A.M.B.1453693325.508241.jpg ImageUploadedByH.A.M.B.1453693346.268243.jpg ImageUploadedByH.A.M.B.1453693361.242419.jpg ImageUploadedByH.A.M.B.1453693373.967011.jpg
    brEad, Tim_with_a_T and kidcampbell71 like this.
  16. Can I move in too?
    brEad and kidcampbell71 like this.
  17. .... holeee' sh#t ! (in a good way of course !!)
  18. Oohh man !
    I know the feeling.
    Don't let it stall -
    my words of encouragement
    Slow motion is better than no motion
    Ask me how I know
    kidcampbell71 likes this.
  19. I think it sounds like an amazing opportunity to hone your talents (which are obvious). I truly envy you. Like an old time Master and Apprentice relationship..
  20. falcongeorge
    falcongeorge
    from BC
    Just a suggestion, but instead of black, have you thought of mixing a dark dark dark green that's almost black?? Philly the Greek posted a '32 that is the sort of colour I am thinking of a while back. I would seriously consider painting the whole car that colour, I think it would work well. I think I saved the photo, will try to find it later today.
  21. falcongeorge
    falcongeorge
    from BC
    Heres the photo in question, to go with your engine colour, you would want a yellower cast to the base colour, this has a blue cast, but you get the idea.
  22. DDDenny
    Cripes George, now I'm not gonna be worth a shit for the rest of the day.
    BTW, did you notice that "Elvis lip" at the bottom of the hood side.
  23. falcongeorge
    falcongeorge
    from BC
    I did. Kinda hard to miss, jumps right out at ya, doesn't it?
  24. 36 Vick
    36 Vick
    from Kerman, Ca
    Started a rough mock up template of the new wheel opening. Still sometime away from creating the wheel opening, BUT this will allow to place the body on the frame, so we can continue with the chassis build
    ImageUploadedByH.A.M.B.1453905426.568025.jpg ImageUploadedByH.A.M.B.1453905446.993259.jpg
  25. 36 Vick
    36 Vick
    from Kerman, Ca
    ]If this is THE Larry Ruth, his credentials came waaay before 2004.[/B]
    His credentials do go waaaay back, for sure. But for sake of not using up to much data uploading his resume, I thought I'd keep it simple!!!
  26. 36 Vick
    36 Vick
    from Kerman, Ca
    I really like that suggestion. The down side to being so far away from paint, is I may be changing the color all together. But if I don't, I will roll with that idea Thank you
    falcongeorge likes this.
  27. Definitely the way to go - will legitamize the look for the car right there; more a custom-bodied/coachbuilt hot rod than a converted post-'34 highboy with stock rear fender openings.
    By the way, any idea on how the rear bustle will be shaped to work with the new wheel openings?
    Steve
    brEad likes this.
  28. 36 Vick
    36 Vick
    from Kerman, Ca
    Please excuse my ignorance. Can you explain the "bustle" cut of the car? Is it like the tri tip or ribeye?
  29. 36 Vick
    36 Vick
    from Kerman, Ca
    Steve, please learn me something. What do you refer to as the rear bustle? I'm eager to learn
    -Levi
  30. Wiki - A bustle is a type of framework used to expand the fullness or support the drapery of the back of a woman's dress, occurring predominantly in the mid-to-late 19th century. Bustles were worn under the skirt in the back, just below the waist, to keep the skirt from dragging.
    I'm not much for words ... I like pictures. The last picture is a good bustle. Where the heck do your wheel wells go ? o_O
    31Vicky with a hemi likes this.
